Fixing That Jet Lighter You Love
Intro: Fixing That Jet Lighter You Love
So I was fixing my jet lighter (by now a fairly archaic design but a very good one and it only cost me£1 at a car boot sale) I used to fix antique lighters with my dad, thankfully jet lighters tend to be a bit more standard for repairs.
So In this I'll cover diagnosis, repair and also dismantling and assembly (most lighters designs' are a common principle... )
Ok so i got a slightly better camera than my phone, it's an ancient canon powershot A60, only 2MP but check out the macro in the pics, it was top of the range once upon a time and it shows.
STEP 1: So What You'll Need for This
Tools
- a small philips head screwdriver (the tiny ones) it almost alway philips head.
-a penknife or a small flathead screwdriver (for adjustments)
-a pair of pliers, needle nose are great her but I can do it with my fake leatherman start to finish (make damn sure the pliers aren't magnetized it's annoying)
-a safety pin or some thin tough wire or a drawing pin (you'll see what I mean if it comes up)
Materials
-some sturdy wire about 24awg (anything that fits will do (again you'll understand pretty quick) is handy
-lighter gas, really helps diagnosis, in fact try the first...
-You may need rubber tubing or a piezo spark depending how you broke it (if you dropped I already know whats wrong. the lighter in this is my drinking lighter because it's made of metal and I know how to fix it)
Materials
STEP 2: Ok Diagnosis Time Doctor
First put gas in the lighter, you should have done this already but this helps us determine alot.
Fill it with gas and listen, it may leak for a up to 30 seconds but that's ok as long as it stops.
Push down the button, is there gas coming out and is there a definite click from the spark (if yes to both this will be easy)
If there's no gas coming out at the nozzle but it's going somewhere then the connection has been broken probably nothing more than the flexible gas line has slipped off the seat of the reservoir end (there's more room here so it fall off that end but it's easy to fix anyway)
If you push the button all the way down and no click go to the shop and buy a really crappy cheap electric lighter, not a bic though, their piezios have no wire.
try turning down the gas a bit (sometimes the gas can't ignite because it going too fast for the tiny arc to heat... This always happens if you set the lighter when it's hot because it starts easier but wont once it's cooled down again.
All of these things are curable, this lighter hasn't many original parts, at one point I was going to hotrod a second nozzle in but There's no room, eventually I'll make an instructable about how to make your own jet lighter.
STEP 3: Opening Your Lighter Up
This step just tells you how to take it all apart.
First look on the bottom, there should be a small (mostly likely philips head) screw not far from the filler valve, unscrew it, usually that is the only thing holding a lighter together, now pull the casing down off the rest (hold on to the cap and carefully pull the casing off) now you should see the guts of your lighter, there's probably 2 pins holding the assembly together. Enter the safety pin, Use the pin or wire to push the pin out of its hole.
now try moving everything apart, careful not to lose anything (yes my pins are made from steel wire but shh the screw came off a tiny circuit board, i didn't lose it, the screw was too long to start with.)
Check the image, the parts should be recognizable, and the note will explain all...
STEP 4: Adjusting the Spark
This is easily the most common problem with jet lighters because they have metal bodies...
Basically the piezo is grounding out to the body or the chassis...
All we need to do is move the wire out and put it against the nozzle so it's touching it, that'll be guaranteeing near 100% performance in lighting. The first picture here shows the spark wire end pulled out and away a bit to so we get a clear idea of where we can put it. Wrapping it around the nozzle is good if there are no close metal body parts but the best is definitely doing it like picture 2. You should have kept all the pins, but really you should hav just left it together had this been the case. Before putting the case on, see if the lighter fires up if so slide the case on again and see if it still goes, if yes screw it back on and go light something up with it (In my case a Marlboro Red but in yours it may be a fuse... )
STEP 5: So I Did That, But I'm Not Getting Anywhere
Simply check where gas is going by pushing down on the lever for the gas valve on the reservoir, look carefully along the gas line, you should see something similar to 'heat wiggles' (from the change in desity between gas and air) if theres a leak, I you have a crappy BBQ lighter kicking around then cannibalize that for some gas line (there's enough for five or six replacements) and if you needed it they're a great source of igniters due to the extra long cable.
If the gas still isn't getting out the nozzle then the nozzle's clogged, symptoms include the lighter bursting into flame for a second during use. take some thin wire or a pin and put it through the nozzle to clear it.
At this point I can't think of much else to go wrong, if the gas filler valve leaks when you fill it up then tighten it. If everything works but the lighter won't light or can't hold a flame turn down the gas flow a bit. If the flame sputters and has trouble keeping going then it's too weak to stay above the nozzle, turn the gas flow up a little. Finally we put it back together.
If there's any problem I have missed comment me and I'll add steps, to be honest I can't think of anything other than components going wrong after this.
STEP 6: Putting It Back Together
Right now we rebuild the lighter
From the picture you should be able to tell your own parts easily enough.
This list goes bottom to top in stacking up the components again, refer to the pictures to make full sense
BOTTOM
- Reservoir
-gas valve lever (best put in before piezo for convenience
-piezo
-button cover/s
-lid top assembly (make sure the gas tubes go back in the right place)
-slide the cover back on and screw on
BOTTOM
- Reservoir
-piezo
-button cover/s
STEP 7: I Do Believe We're Done
Again if there's anything I missed or any questions comment me and I'll do my best to help.
237 Comments
manda1420 3 months ago
Hey guys! Could anyone help me with how this goes together? PLEASE!! I can't find anything about it. It says Torch Blue on it but when I look it up it tells me it's something else. Any help is appreciated! Thank you!!
Laura Johnson 1 year ago
JasonW132 4 years ago
BUDDAH5192 4 years ago
davidwmorris033 1 year ago
BoojyH 3 years ago
first hold your lighter up and with only the air from your mouth blow as hard as you can straight into the lighter were the flame comes out, 95% of the time this will fix it. DO NOT USE COMPRESSED AIR. This will mess it up real bad. #2. A clogged jet from burning cheap fuel is a hard one. You have to remove the jet orifice holder, very small barrel shaped pc. that comes apart at the bottom. You need to use quality pliers, needle nose, to unscrew the bottom off. Inside you will find a stainless steel filter screen, a washer to separate it from the jet and then the jet itself. You the butane to clean out the screen while holding it with a paper towel. This is dangerous, dont blow yourself up. rubbing the disc in the paper towel and spraying with a little butane while in the paper towel should clear it. Reassemble. If this didn't fix it then either you didnt clear it or the jet was damaged somehow. This shouldn't actually be tried by anyone because it is dangerous. Butane is flammable. Don't buy cheap fuel
violentred7342 2 years ago
kirkchilders96 3 years ago
This is also the reason why jet fighters took over 20 years from first flight to be really useful, as the fuel needed to be both plentiful and high quality to keep such a engine going. The benefit you get from them however is enormous capabilities.
jimpaulson1958 4 years ago
kmg9150 1 year ago
sandy328 4 years ago
kmg9150 1 year ago
gthartney 2 years ago
Anyhow, anyone know how and which way it goes back together? I suppose I could figure it out, but I'd have to do some "trial and error" type stuff, just in case. I appreciate any input.
kmg9150 1 year ago
OrgansRFun 2 years ago
kmg9150 1 year ago
Phily888 4 years ago
sir.hunterludwig 4 years ago
zombieregime 2 years ago
If you push the button and there's no click, it's because the spring loaded Hammer that strikes the crystal has not reset on to the igniters sear. The arc generation sequence goes like this: 1. The striker button is held up against a spring in the crystal housing. The hammer is inside the striker button pushed down by another spring against the Hammer sear face of the crystal housing. 2. Pressing on the striker button compresses both springs. 3. As the hammers spring compresses it twists a small amount, enough for the hammers pins to slide off of the sear and release the built-up energy in its spring striking the crystal. 4. The crystal compresses and builds up a voltage potential between the negative and positive faces through the piezoelectric effect. 5. There's a spark somewhere. 6. As you lift these striker button the pin slide along the guide rails until they reach the hammer's sear. When the pins clear the sears face the angled guide rails on the bottom of the striker button rotate the hammer onto the sear faces due to downward pressure from the hammer spring. 7. The spring in the crystal housing pushes the striker button up until the hammer guide pins contact the top of the sear faces. 8. The ignitershould now be reset for another press*
If you are getting a weak strike or no click sound at all, chances are at the bottom of the striker button one of those angled guides that guide the hammer pins back into the sear box has cracked along the long side. This is a common structural flaw as if you look at the bottom of the hammer housing in the striker button the two pins on the side of the hammer have to slide up to opposing corners and then they will rotate onto the angle guide faces which then cause it to rotate all the way to the other two opposing corners. As the hammer comes back up one of the pins will sit on that crack and not be rotated back onto the sear faces or at least not rotated far enough because that piece of plastic isn't pressing hard enough against the pins to rotate the hammer. This damage occurs when you don't push the strikerbutton fast enough and the hammer pins hit the top of the angled guides in the striker button before fully coming down on the crystal, this mechanical shock eventually cracks the plastic.
This is a flaw I'm sure they know about, but will not fix, because sales are just too good with a slightly flawed product that no one can figure out so they just buy another one.
But no, they do not run out of electricity.
Not sure how compressed air can do that, unless you're using an actual compressor instead of canned air (why with something so small?)
