Introduction: Free Firebase Hosting and Realtime Database
About: Experience sharing is better than giving advice
Firebase free secure (https) hosting and realtime database, (Spark Plan) offer ~ 10GB free.
after this project you can send data from text box using button and get it to a label from the database using easy steps and codding.
ready to start ?
Step 1: Open Firebase Link to Create a Project
https://firebase.google.com/
click on Go to console then click Create a project
Step 2: Create a Project
step 1 of 3 - type your project name
step 2 of 3 - enable google analytics if needed
step 3 of 3 - create project
Step 3: Build a Realtime Database
click on real-time database from build menu
create database
setup data base
choose test mode
ready to start hosting steps
Step 4: Add Html App to the Project and Hosting
from project overview add web app
register your app
copy the SDK data and save it you will need it on coding
from bulid menu select (hosting) then get started
Step 5: Coding
Open visual studio code and make a new folder not file.
new file name index.html and project.js don't change the file name to avoid a bug "error on codes"
past the SDK data on java file as the attached image , you saved it while add app steps
HTML Code
<!DOCTYPE html>
<html>
<head>
    <meta charset="utf-8">
    <title>Project1</title>
    <meta name="viewport" content="width=device-width, initial-scale=1">
    <script src="https://www.gstatic.com/firebasejs/7.6.2/firebase-app.js"></script>
    <script src="https://www.gstatic.com/firebasejs/7.6.2/firebase-firestore.js"></script>
    <script src="https://www.gstatic.com/firebasejs/live/3.1/firebase.js"></script>
    <script type="module" defer="" src="project.js"></script>
</head>
<body>
    <h1>Project1 Firebase Realtime Database</h1>
    <div>
        <div>
            <label> the current value : </label>
            <label id="value"> value </label>
            <button type="submit" id="data_get"> send </button>
            <br><br>
        </div>
        <input  id="data_input_text" name="fname" >
        <button type="button" id="datainput_send"> send </button>
    </div>
</body>
<footer>
    <p>Best Regards</p>
</footer>
</html>
JAVA CODE
var firebaseConfig = {
    apiKey: "copy paste SDK",
    authDomain: "copy paste SDK",
    databaseURL: "copy paste SDK",
    projectId: "copy paste SDK",
    storageBucket: "copy paste SDK",
    messagingSenderId: "copy paste SDK",
    appId: "copy paste SDK",
    measurementId: "copy paste SDK"
firebase.initializeApp(firebaseConfig);
console.log(firebase);
const get_button = document.getElementById('data_get');
get_button.addEventListener("click", getData);
function getData() {
 const dbRef = firebase.database().ref();
  dbRef.child("sensor1").child("read_data").child("read").on('value', (snapshot) => {
    if (snapshot.exists()) {
      console.log(snapshot.val());
      var cornumber = snapshot.val();
      document.getElementById("value").innerText= cornumber ;  } else { console.log("No data available"); }
const buttonn = document.getElementById("datainput_send");
buttonn.addEventListener("click", send_data);
function send_data() {
    var data_input = document.getElementById("data_input_text").value;    var data_input_number = Number(data_input);
    firebase.database().ref("/sensor1").child("read_data").update({
        read: data_input_number,
    }, (error) => {
        if (error) { alert(error) // The write failed...
        } else { alert("data sent to firebase") // Data saved successfully!
Step 6: CMD Step to Start Firebase Deploy
install node.js program from the link https://nodejs.org/en
open Command Propmt and past
npm install -g firebase-tools
after finished the installation past the below to login to your google account
firebase login
type the below to open Firebase director
firebase init
select the project name id and type alias
firebase use --add
then type the below then Y to initialize your home directory then select the feature you need like hosting and real time data then choose you project by select >Use an existing project
firebase init
press y for ready confirm then select realtime database and hosting using space from keyboard and press enter
choose the project you will use to make the hosting after you receive Firebase initialization complete text
past the files on the hosting directory and now you are ready for deploy using
firebase Deploy
you will receive the hosting URL after finish
Best Regards
Step 7: Testing
test your website from the link you get from firebase deploy and Firebase realtime database
for modification you can use firebase serve.
