Introduction: Free Nine Volt Battery Clips and Small Enclosures
Recycle your "dead" 9v batteries into something useful and help save the planet.
Step 1: Tools and Supplies
Tools:
Soldering iron
Flat head screwdriver
Supplies:
A 9 volt battery with a metal case (I recommend Duracell)
Solder
Two small bits of wire
Soldering iron
Supplies:
Solder
Step 2: Open the Case
Use your screwdriver and pliers to carefully pry back the top of the case and empty all the contents of the battery.
Step 3: What You'll Find Inside
What should come out of the battery is 6 AAAA cells, the bottom cover, the top cover, and the case itself. If you had lollipops, a small rodent, and a sock come out of the battery then you may have done something wrong.
Step 4: Making the Battery Clip
Heat up your soldering iron and solder two your two wires onto the contacts on the back of the top cover.
Step 5: The Case
The Battery case can have many purposes. Some examples are: Flashlights, Holders for small electronic parts. Use your imagination. Check out my other instructable on how to turn it into an electric hand warmer/heater https://www.instructables.com/id/Electric_Hand_Warmer/
Step 6: The Cells
For more information about the AAAA cells and how you can use them see kipkays 9 volt battery hack. https://www.instructables.com/id/9_Volt_Battery_Hack/
Step 7: Thanks
I hope you enjoyed my instructable and keep doing whatever you can to save our planet. Please vote at the top of this page and feel free to comment/rate, all I ask is that you post no insulting comments considering I'm only 13.
