Introduction: Futuristic Truck!
Presenting the future of the truck! It is based off of a Halo Warthog.
it's 15 inches long, 6 wide, and 9 tall
it also rolls.
the files are below. The next steps will explain how to put them together. I was under a time crunch for this, but some of the bigger pieces will snap together. If you have a small Maker-bot, and want to put it together, you can follow my idea, and make them snap together.
the color in Solidworks is 70 green, 0 red, 0 blue, for the green
for black it's 0 green, 0 red, and 0 blue
it also rolls.
- rollcage.SLDPRT
- wheel for warthog.SLDPRT
- transfer case.SLDPRT
- side for engine compartment.SLDPRT
- seat.SLDPRT
- quarter panel.SLDPRT
- other quarter panel.SLDPRT
- other motor.SLDPRT
- motor.SLDPRT
- hoof.SLDPRT
- front side for engine compartment.SLDPRT
- Floorboard.SLDPRT
- door.SLDPRT
- dashboard.SLDPRT
- bed.SLDPRT
- bed 2.SLDPRT
- base for warthog.SLDPRT
- base for engine compartment.SLDPRT
- back side of engine compartment.SLDPRT
Step 1: Seat/door Assembly
1. open a new assembly and insert "base for warthog".
2. insert two of "seat"
3. mate the holes of "seat" with the holes of "base for warthog"
4. Mate the top face of "base for warthog" with the bottom face of seat.
5. repeat with other seat
6. Insert two of "door"
7. mate the edge of door with the chamber on the edge of the base
8. Select the inside edge of the door and mate it with the inside edge of the "base for warthog" chamber. Alos mate the front side of "door" with the front of "base for warthog".
9. do the same with the other door
Step 2: Floorboard/dashboard Assembly
10. Insert "floorboard"
11. Mate the pegs of "floorboard"with the holes on the front of "base for warthog"
12. Mate the faces with the holes and pegs of the two parts together
13. Insert "dashboard"
14.mate the chamber of dashboard with the top of "floorboard"
15. mate the front edge of the dashboard chamber with the front edge of "floorboard" with the front edge of the chamber of "dashboard".
16. mate the driver side of "dashboard" with the driver side of floorboard point
Step 3: Bed/engine Compartment/transfer Case Assembly
17. insert "bed 2"
18. Mate the pegs with the holes of "base for warthog" like with the floorboard
19. Mate the front face of "bed 2' with the back side of "base for warthog"
20. insert "bed'
21. mate the bottom, smooth face of "bed" with the top face of "bed 2"
22. mate the front side of "bed" with the back face of "base for warthog"
23. mate a side of "bed" with a side of "bed 2"
24. insert "transfer case"
25. mate a long, flat side of transfer case to the bottom of "base for warthog"
26. mate the smooth, thin side of "transfer case" with the side of the thin line on the bottom of "base for warthog"
27. mate one of the side of "transfer case" with holes in it, with either the front or the back of "base for warthog"(sorry don't have picture)
28. Insert base for engine(sorry don't have pictures for the engine compartment assembly)
29. Insert 2 of "side for engine compartment"
30. mate the thin, long sides of "side for engine compartment" with the chambers of "base for engine compartment"
31. mate the other thin, short sides of "side for engine compartment" with the front or back face of "base for engine compartment
32. insert "back of engine compartment"
33. mate the large, flat face of it with the thin, short sides of "side for engine compartment"
34. mate the bottom of "base for engine compartment with the bottom of "base for engine compartment"
35. insert "front side of engine compartment"
36. repeat steps 33-34 with "front side for engine compartment", making sure that the long extrusions touch "back of engine compartment"
20. insert "bed'
Step 4: Motor/wheel Assembly
37. Insert 2 of "motor", and 2 of "other motor"
38. Insert 4 of "wheel for warthog"
39. mate the inside rim of "wheel for warthog" with the cylinder of "motor"
40. mate the inside face of "wheel for warthog" with the inside face of "motor" (see pictures)
41. do the same for the other three wheels on the other "motor" and 2 "other motor"s
41. select the top of the small extrude of "motor", and mate it with the top of the hole inside "transfer case"(make sure the wheel is facing out. If not, use the other hole on the same side.
42. Mate the front of the small extrude of "motor" with the end of the hole in transfer case
43. Mate the side of "motor with the corresponding side in the hole of "transfer case"
44. do the same with the other "motor" and "other motor", making sure that the wheels are facing out
Step 5: Rollcage/hood Assembly
45. insert "rollcage"
46. mate the pegs of "rollcage with the holes in "base for warthog"
47. mate the bottom of "rollcage" with the top of "base for warthog"
48. Insert "hoof"
49. mate the thin edge of "hoof" ( the one without the fillets) to the back of "dashboard"
50. Mate the bottom of "hoof" with top side of the thin extrude of "dashboard"
51. Mate one of the other thin sides of "hoof" with the corresponding side of "dashboard"
48. Insert "hoof"
Step 6: Quarter Panel Assembly/ Finish
52. insert 2 of "quarter panel"
53. mate the chamber of "quarter panel" with the side of "hoof"
54. mate the bottom edge of the chamber of "quarter panel" with the top edge of "hoof"
55. Mate the back, thin side of "quarter panel" with the front, thin side of "door"
56. do this for the other "quarter panel"
57. Insert 2 of "other quarter panel"
58. mate the chamber of "other quarter panel" with the side of "bed"
59. Mate the top of the chamber on "other quarter panel with the top edge of "bed"
59. Mate the rear short, thin side of " other quarter panel" with the rear side of "bed"
60. do the same with the other "other quarter panel", on the other side
61. mate the rear face of "back of engine compartment" with the back of "dashboard" (don't have picture)
62. Mate the top of the "back side of engine compartment" with the bottom of "hoof"( don't have picture
63. Mate the side "extrusion of front for engine compartment" with the side of thin extrusion of "hoof"
64. Congratulations you have finished this instructable. Hope you enjoy!
