Gear Teeth Repair With a Candle!
Intro: Gear Teeth Repair With a Candle!
In this video I'll show you how you could repair a broken gears teeth at home with a very simple technique.
How I did it - you can check by looking DIY video or you can follow up instructions below.
For this project you will need:
Materials:
- Wax candle
- Epoxy resin
- Silicon
- 50mm PVC pipe piece
- Candle in a metal cup
Tools:
- Rotary tool with grinding and cutting disc Link to product!
- Hacksaw or any saw to cut PVC pipe
- Utility knife
- Lighter and small metal can
- Sanding paper or sander (80 grit)
STEP 1: The Broken Gear & Small Clean Up
This is a broken gear from lawn mover. The device is still going strong, so I decide to fix this gear and get back the lawn mover to work. With a rotary tool I cleaned broken place and made it a bit more even. After that I grab a diamond cutting bit and made few hole for better and stronger bond with upcoming material.
STEP 2: Preparing Form
I cut a short piece of 50mm PVC pipe. With sanding paper made it perfectly flat. Then with a utility knife made a cut out to get a bit flexing form, which perfectly sit in healthy gear teeth's.
STEP 3: Securing and Sealing Up
With a pair of flathead woodscrews secured the gear to the surface. And to make it water tight - sealed with a plasticine.
STEP 4: Melting Vax From a Candle
With a utility knife I chopped a regular candle and placed all pieces to small metal can. Lighted up the candle in the metal cup and with a help of managed wire holder placed the cup over the light. Keep it there until the wax was completely melted.
STEP 5: Pouring Into a Mold
When the wax was liquid as water - I poured it into a prepared form and let it to cool down.
STEP 6: Taking Out the New Template
When wax cooled down I removed the from and with utility knife scraped all excessive wax to make the part flat with gear. After that I carefully slide down from the teeth's. In my big surprised - I was able to managed that in the very first attempt. In a result I had a perfectly negative form of my gear teeth's.
STEP 7: Placing Wax Form In
When I got the perfect wax negative template - I placed it over the missing teeth part. With a help of small plastic piece and few drips of silicon - I sealed the newly formed mold.
STEP 8: Secret "souce"
I mixed a two components epoxy resin with small part of white cement. First I mixed one epoxy resin component with a white cement, and after that added an epoxy hardener and give a good mix again. When I was satisficed with the consistency I poured it in to the mold and let to cure overnight.
STEP 9: Removing From Mold and Cleaning
Next day the epoxy resin was rock solid, so it was ready to take out of the mold. Scraped out all silicon parts and go to the belt sander to even the epoxy overfill evenly to the gear. With a help of rotary tool and small sanding attachment recreated the inner gear lines
STEP 10: Removing Wax
Lastly I removed the wax. This time it wanted slide off as previously, but with small flat screwdriver and removed all bigger wax parts and rest of them was brushed out with a brush.
STEP 11: Stuning Final Result!
And here it is - my broken gear has new, perfectly formed teeth. I'm more than happy with the result, and the gear is now running in my lawn mover without any issues. I hope this was helpful:)
13 Comments
anjoze 1 year ago
How to vote for the contest?
Why the cement? Color or strength?
Mad4400 1 year ago
To make the gear teeth harder wearing, so yes strength.
freiheitsgrad 1 year ago
Anyone here from Germany? Does 'white cement' translate to 'Gips'? Nice solution, btw. Thanks for the detailed explanation and sharing it. Keep going!
Mad4400 1 year ago
Not from Germany, but white cement is limestone (calcite) and china clay (kaolinite). It is similar to cement used in concrete, but has slightly different properties. Its addition to the epoxy resin would have most likely been to strengthen the repair area and reduce any wear on the new gear teeth when in service. "Gips" I believe is gypsum (selenite) which, in its raw form, is often found in the same areas as china clay.
schreib 1 year ago
You must be referring to the white silicone caulk he used to seal the clear plastic. . .
white = weiss in German and silicone is the same worldwide.
Caulk is not necessary to use.
He used white pigment to mix with two part adhesive Epoxy for the main pour material.
ElectroFrank 1 year ago
Very useful. In step 8, I thing "souce" should be "sauce".
Also in step 8, what is meant by "white cement" ?
In English, "cement" means "glue" (or the grey powder used in making concrete).
olderbutnowiser 1 year ago
Perfect and simple. Who needs a milling machine or 3D printer!
schreib 1 year ago
Amazing. All I needed to do is watch the video, no need for text, not even one spoken word. You did a fantastic job both in arriving at a "stunning" solution and at presentation. Excellent.
All I can think to add is to use carbon black instead of white pigment(TiO2?) and to show video of it in operation on the device you are repairing. Fantastic job.
DDMGT 1 year ago
Great concept, well explained! I hope I never need to use this but I’ll be sure to give this a try if ever needed!
technovative 1 year ago
Comprehensive easy to follow presentation of a clever repair technique. Well done.
AjarDesign 1 year ago
Awesome! Very clever
implaxis 1 year ago
I have a broken gear clock that this method would work great for!
leethayer8 1 year ago
Brilliant! Very well documented.
