Introduction: Generative Ableton Push 2 Stand
A 3D printed and laser cut stand for the Ableton Push 2 controller.
Software: Autodesk Fusion 360, Adobe Illustrator, BambuStudio, Hardware: Bambu Lab X1 Printer, Laser Cutter. Materials: Green PLA, Wood, Steel.
Step 1: Initial Model
First, I modeled an initial version of the stand. Each leg is split in two in order to fit in the dimensions of the Bambu Labs 3D printer bed. The upper and lower parts of the legs and planks are fastened together with screws.
Step 2: Prepare for Generative Design
I subtracted geometry from the initial design to allow Autodesk Fusion 360's generative design algorithm to create supports for me. I added negative space components to prevent the generative design from obstructing me from inserting the screws during assembly.
Step 3: Selection of Generative Design
I selected two from several different generative outcomes, so each leg would be slightly different. I tended towards the outcomes which had more negative space, for aesthetic value.
Step 4: Laser Cutting
I exported the sketch for the planks as a DXF file, then brought it to Illustrator to then export to the laser cutter. The screw holes were engraved, then manually drilled and tapered.
Step 5: 3D Printing
The parts were then sliced in BambuStudio, and exported to the Bambu X1 printer.
Step 6: Assembly
I joined the two parts of the leg assembly with machine screws and nuts. The wooden planks were joined to each leg with flat head machine screws and nuts.
Step 7: Test
It worked great :)
Step 8:
