Introduction: GeoTrax Outhouse Model
GeoTrax is a model train system from Fisher-Price is a remote controlled train, plane and truck system that is extremely rugged and fun for a wide range of ages from the very young to the surprisingly old. The problem is that unlike "scale" model systems there are not a lot of models you can add to layouts to make them interesting. In fact the only ones I know of are those provided by Fisher-Price.
This model of an outhouse is another in a set of models for use with your GeoTrax layout. This model is simpler to assemble and may be a better model for a child to build. Also the humor of the model is (generally) more amusing to a kid.
Step 1: Print and Cut Out the Model.
Print the image below and if you prefer glue it to something stiffer like poster board or foam core.
Step 2: ASSEMBLY METHOD 1: Assemble on Card Board
Glue the picture to some light card board or poster board. This is the best compromise between complexity and sturdiness.
The roof is meant to form a gap with the slightly higher door panel. Fold the tab over the door and use it to glue to the roof to hold it in place.
The odd color shift is due to my printer being low on ink.
Step 3: ASSEMBLY METHOD 2: Assemble on Foam Core Board
This makes the most rigid model, but is the most work.
If you use foam core you should cut 45 degree cutouts at each fold point so that the model comes together. You do not need the tab on the left side of the model or at the top of the door panel when working with foam core due to its thickness.
Look at the attached pictures for details.
Step 4: ASSEMBLY METHOD 3: Assemble With Paper Only
This is the easiest, but it is also VERY flimsy.
Step 5: All Done and Some Suggestions
You are all done, this is a very simple model, which kids (of all ages) will have fun assembling.
Suggested improvements:
1) Solid fill. You could fill the core of the building with some modeling clay to give it some weight so that a simple breeze wonât knock it over.
2) Add a base. Adding a paper base that can extend under nearby track (like some of the signs Fisher Price provides) for more stability.
