Introduction: Get Rid of Fleas While You Sleep
About: Jack-of-all trades, master of some. I would probably be much more modest if it wasn't for these delusions of granduer that I suffer from.
This is a trick I learned from my grandmother when they lived in North Carolina.  They had a dog that was always outside romping around in the woods.  He would often bring home little hitchhikers, and this was Nana's solution.
The best part about this trap is that there are no chemicals to worry about your pets or small children coming into contact with.
Step 1: Things You Will Need
- A small desktop style lamp
- A shallow bowl.  I found that the cheap aluminum pie tins work great for this, but if you don't have one of those any shallow bowl will do until you get one.
- Liquid Soap
- enough water to fill the bowl about half to three quarters full
Step 2: Setup
set the bowl in a regularly used room, just make sure it is out of the way enough that it won't get knocked over by anyone. I set mine behind the recliner because it stays a set distance away from the wall and no one goes behind it.
Fill the bowl with the soapy water.  Adding the soap to the water is essential for the trap to work properly, because the soap decreases the surface tension of the water so that once the fleas hop in they can not manage to swim back to the edge and crawl out.
set the light directly over the bowl a few inches from the surface.
You will find the most dramatic accumulation of fleas will occur overnight ,as long as you remember to leave the lamp on.
Step 3: Maintaining Your Flea Trap
This is the really hard part ...
Change the water once a day.
