Introduction: Getting Started With NRF24L01 Wireless Transceiver Module
About: For more project and tutorial visit my YouTube Channel Smart Technology
In this project, we are going to learn how to use NRF24L01 Transceiver Module in order to make a wireless communication between two Arduino boards where using the PushButton at the first Arduino we will control the LED at the second Arduino.
The purpose is to discover the perfect way to communicate wirelessly between Arduino’s by using the NRF24L01 Wireless Transceiver Module.It alows us to remote things wirelessly.
Hardware components :
1. Arduino Uno × 2
2. NRF24L01 Transceiver Module × 2
3. Base module with voltage regulator × 2
4. PushButton
5. LED
6. Breadboard
7. Wires
Software apps :
1. Arduino IDE
Step 1: NRF24L01 Features and Specifications
Features of the NRF24L01 Wireless Transceiver Module :
  • žCost (between 1$ to 3$ regarding to the type version)
  • žRange
  • žAvailability
  • žEasy to use
Types of the NRF24L01 Wireless Transceiver Module :
There is two types of NRF24LO1 :
  • žNRF24L01 with antenna (About a Kilometer in openspace)
  • žNRF24L01 without antenna (About 50 meters in openspace)
Applications of the NRF24L01 Wireless Transceiver Module :
  • žWireless home automation
  • žDrones remote control
  • žRemote sensors for temperature, pressure, alarms, much more
  • žRobot control and monitoring
The power consumption of the NRF24L01 Wireless Transceiver Module :
  • žThe power consumption of this module is just around 12mA during transmission
  • žThe operating voltage of the module is from 1.9 to 3.6V
Step 2: Watch the Video for More Details
Step 3: Problem to Be Overcome
Many users confront issues with NRF24L01 module.the source of these issues often come from the 3.3v Power.due to themodule does not have enough current capability.this is why I recommend to either use:
  • žBase module with voltage regulator and bypass capacitorsfor stability
OR
  • ž3.3 uF to 10 uF (MicroFarad) capacitor directly on the module from +3.3V to Gnd
Step 4: Schematic
CE and CSN pins can be connected to any digital pins. Then in RF24 library, you can specify which pins you used. I chose pins 8 and 9 because I will use them in the examples.
In our case we will use the Arduino Uno this is why you should follow this instructions (or follow the picture above) :
  • MOSI is connected to the digital pin 11
  • MISO is connected to the digital pin 12
  • SCK is connected to the digital pin 13
  • SS (not used)
Note: While using the NRF24L01 you have to remember that these digital pins won’t be available.
Kindly watch the video which explained all steps clearly.
Step 5: Download RF24 Library
In this project we used RF24 library, which can be downloaded on Github: RF24 library
1. First you need to click on “Download ZIP” button
2. Extract the zip file to your Arduino home directory: Arduino/libraries on Linux or Documents/ Arduino/libraries in Windows.
Step 6: Transmitter Arduino Code
Transmitter sketch will look like:
/** Arduino Wireless Communication Tutorial
*      Transmitter Code
* by Smart Technology,  <a href="https://makesmarttech.blogspot.com/" rel="nofollow"> https://makesmarttech.blogspot.com/
</a>
* Library: TMRh20/RF24,<a href="https://tmrh20.github.io/RF24" rel="nofollow">https://tmrh20.github.io/RF24</a>
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define button 7
RF24 radio(8, 9); // CE, CSN
const byte address[6] = "00001";
boolean buttonState = 0;
void setup() {
  pinMode(button, INPUT);
  radio.begin();
  radio.openWritingPipe(address);
  radio.setPALevel(RF24_PA_MAX);
  radio.stopListening();
void loop() {
delay(5);
    buttonState = digitalRead(button);
    radio.write(&buttonState, sizeof(buttonState));
  }<br>
Step 7: Receiver Arduino Code
Receiver sketch code will look like :
*      Receiver Code
* by Smart Technology,   https://makesmarttech.blogspot.com/
* Library: TMRh20/RF24, https://tmrh20.github.io/RF24 */ #include <SPI.h>
#include <nrf24l01.h> #include<RF24.h> #define led 7 RF24 radio(8, 9); // CE, CSN const byte address[6] = "00001"; boolean buttonState = 0; void setup() { pinMode(7, OUTPUT); Serial.begin(9600); radio.begin(); radio.openReadingPipe(0, address); radio.setPALevel(RF24_PA_MAX); radio.startListening(); } void loop() { delay(5); radio.startListening(); while (!radio.available()); radio.read(&buttonState, sizeof(buttonState)); if (buttonState == HIGH) { digitalWrite(led, HIGH); } else { digitalWrite(led, LOW); } }
Step 8: For Support
You can subscribe to the my YouTube channel for more tutorials and projects.
Subscribe for support. Thank you. Go to my YouTube Channel -link https://goo.gl/EtQ2mp
