Introduction: Glass Bottle Lamp
Hey guys,
This is a normal glass bottle that has been decorated. There won't be many supplies needed still you will be able to be creative and use it as a beautiful mood lamp. I am sure that you will be satisfied after you've made it by yourself. It will be fun and very easy to make, so have fun!
- Glass bottle
- Glass Paint Set
- Decoration Light
Step 1: Draw Guiding Lines
Take the glass bottle that you don't use and clean it.
Draw lines with the black color paint that came along the glass paint set. Be sure to leave spaces in between the lines so that you can fill it with colors later.
If drawing lines is done, leave it for like 10 or 20 minutes to dry.
Don't worry even if there are scratches because they will eventually not be seen after you've finished decorating.
Step 2: Color It!
Take a dry tissue paper and check if the guiding lines are dry. If they are, start coloring it with the choice of yours. I chose red, pink, and yellow for mine.
After you are done with it place it in front of sunlight, it would not only be eye candy but also will let it dry faster.
Leave it for like 20 to 30 minutes.
Step 3: Put in the Light
If the colors are dry, put in the decoration light into the bottle. I have used the light that was used for Christmas tree decoration so it had different colors like blue, green, white, and pink.
Even if the decoration light has one color, it would be good enough or better as the colors painted will shine.
Step 4: Done!
Once you have put in the decoration light, turn off your room light and you will see your bottle shinning. Isn't it beautiful? I wish I can see yours too. Share this with your friends so that they can make it as well.
Wish you had fun, thank you. :)
