Introduction: Good Wizards Magic Staff
A while ago I saw a Adam Savage one day build of a lantern ( https://www.tested.com/one-day-builds/896382-adam-savages-one-day-builds-gaslamp-lantern-prop/) go to 5:30. and this inspired me to make a Halloween prop for my son. This is a simple and fun project and the end result could be adapted for other holidays or costumes ( I'm thinking of a Candy Cane one for Christmas)
Disco light bulb
Plastic pipe
Press Button Switch
Batteries and holder
Wire
Optional candle stick
Paint and hot glue
Step 1: Step 1 THE BULB
We have had a couple of these for ages but they don't fit any of our sockets, then having seen Adam's video I decided to open one up.
Step 2: Step 3 the Electrics Pt 1
I remove the control widget and solder in a new battery to power the lights and the small built in motor. I then connect a push switch.
Step 3: Step 4 the Electrics Pt 2
I cut a length of pipe to With the hole drilled I thread the wire up the plastic and glue the the switch in place.
Step 4: Step 5 the Bulb Holder
I used an Pound Shop candle stick holder which as a miracle was the perfect size for the bulb. I cut out a plug on the drill press and and then drilled a hole in both and threaded the wires through. The candle stick will house the battery holder.
Step 5: Step 6 Painting the Staff
Using the hot glue method (apologies to the person who used tin foil but I now cant find your Instructables, but thanks) I then painted on 1 coat of PVA and 2 coats of external grade paint stain.
Step 6: Step 6 Painting the Bulb Holder
Using rattle can and glitter already in the shop I paint the Bulb Holder. I also drilled a couple of holes and fixed 2 screws so I can change the batteries.
Step 7: Step 7 the Finished Staff
The finished staff works great . The images were taken in a fairly light room. In a dark room or even outside the rotating effect is great.
