Introduction: Guest Room Journal
Having a journal in your Guest Room is an extra special touch that visitors will appreciate. I wanted to make one, and having purchased a few journal making books some years ago, I thought now would be a good opportunity to start learning how. This book is very basic, really no special materials are required. I just used what I had on hand to get the journal completed.
- pretty paper, one side plain, other side printed
- glue stick, photo glue
- scissors, rotary cutter
- ruler, straight edge
- big needle, strong thread
- optional: templates, printer for quotes
Step 1: Create Pages
I used 12 x 12 paper, cut in half, then folded in half
Used a variety of prints and patterns that looked nice with each other, and also matched the color scheme of the room.
I ended up with 20 pages, using too many can create bulk so that the book doesn't stay closed.
I found some interesting and funny quotes online. I printed them out on light brown paper, cut them out, and glued onto the page sides where there is a print, as you can't write on them.
Step 2: Create Outer Cover
The outer cover should be slightly larger and stiffer than the pages.
I glued two halves back to back, then added a little border.
I used some quilt templates to create a flower, similar to what I have on the curtains in the guest room.
I would press my work between books to keep everything flat during the glue drying.
Step 3: Sewing the Binding
Typically, the pages are sewn together, then the cover is glued on later to hide the binding. Since I wanted to keep this simple, I sewed everything as one unit.
Using an awl, or simply the needle you'll be using, poke 3 holes equidistant from each other, through all thicknesses. Be sure all papers and cover are lined up nicely.
Using needle and about 18" of upholstery/heavy-duty thread, feed through holes according to diagram.
Tighten everything up nicely, and knot on out side. Create a loop/knot/tassel combo if you'd like.
Step 4: Display Your Book
If you have a writing desk, or just a nightstand, be sure to display your book with an attractive pen, to encourage your guests to share their thoughts and experiences.
