Introduction: HOW TO RESET GALAXY NOTE 2
Samsong Galaxy Note 2 is very multi-tasking and powerful device because you can do anything with easy and simple way. but sometimes Note 2 get some problems such as freezing or stuck for some reason. the solution is normally to reset the device. And there are three ways to do this.
Step 1: OPTION 1#reset From the Software Menu
turn the device on
Step 2:
go to menu setting
Step 3:
from personal menu choose back up reset
Step 4:
choose factory data reset to reset your phone
Step 5:
choose reset device
Step 6:
choose delete all
Step 7:
when you choose delete all your device will wipe cleaned from all data and programs.
Step 8: OPTION 2# Reset From the Hardware Key Button :
turn off your phone
Step 9:
press and hold together volume and home key button and power button for a few seconds
Step 10:
you will see the hardware menu so use the volume button to go up and down in the menu and choose wipe data / factory reset
Step 11:
choose delete user data
Step 12:
that usually fixed the problem and returned your phone wiped cleaned new
Step 13: OPTION 3#the Easier Way to Reset Your Phone With the Secret Code
turn your phone on
Step 14:
dial *2767*3855*
Step 15: WARNING
be careful because all data will removed from the phone so back up your data before you reset your phone
