Introduction: HOW TO USE SOUND BOARD
Material:
Soundboard (Adafruit Audio FX Mini Sound Board - WAV/OGG Trigger - 2MB Flash)
Link: https://www.adafruit.com/products/2342
Jumper Wire
Link:http://www.amazon.com/Breadboard-Jumper-Wire-75pcs...
Wire
Link:http://www.conwire.com/electronic-wire-cable/
Speaker w/amp
1/8'' Audio Jack
Step 1: Step1: Insert Sounds You Want
Record sound/ choose the sound you like (sound format needs to be wav) and put them inside the soundboard
Step 2: Step2: Link Wire/ Jumper Wires With the Soundboard
From the upside, link one jumper with the ground (Gnd), and link the other jumper (not the same one) with the right (R) connecting to the speaker.
From the downside, link one side of the jumper wire with the G, and other side, you can touch the numbers from 0 to 7 as how many tracks you put inside your sound board. Thus, it will generally look like this.
Step 3: Step3: Connecting to 1/8'' Audio Jack
Close up of the small part of the image. The one that has hole link to the ground (negative). The plug needs to connect to the circle connector.(like the image below)
Step 4: Step4: Connecting With the Speaker
Use the speaker W/ AMP, open it by turning it to one side, and then take out the connector from the bottom of the speaker, connecting the speaker connector with the 1/8'' Audio Jack.
Step 5: Step 5: Final Look Like
So, there is what it looks like.
Here is a link of what it is functioning on one of my group project.
