Introduction: Hakima Roof Rack - Poor Man's Strut Channel Cross Bars
My SUV came with a basic luggage rack.  What I really needed was something with the functionality of a Yakima or Thule cross bar but with a dumpster diver price tag. For less than the cost of a single store-bought cross bar I was able to bodge a reasonably functional bar using strut channel that I purchased from Home Depot.
Clamping a bar to an existing roof rack ain't exactly rocket science.  It's the strut channel that does all the heavy lifting in this Instructable, I'm just here to type up the notes.  If you are already familiar with strut materials skip ahead to the Step 1.
If you're not sure what strut is just look up in a grocery store and you'll see it.  Strut is that stuff suspended from a ceiling by rods to support electrical conduit, refrigeration lines, plumbing, etc. in commercial buildings.  Think of an Erector Set in real world scale. While it ain't pretty, strut channel has a lot going for it.  (How I love thee, let me count the ways.)
    Inexpensive and readily available
    Galvanized steel for strength and durability
    C- channel in cross section for added rigidity
    Predrilled holes create multiple points of attachment
    Flat sided for easy connections
    Easily drilled with power drill
    Easily cut with power tools - I haven't tried a hacksaw on it yet
    Matched perfectly with special connecting hardware
    Did I mention inexpensive?
Step 1: Gather Your Materials and Tools
You will need
    Strut channel (comes in 10 foot lengths)
    U-bolts (two per cross bar)
    Metal cutter of choice - reciprocating saw, hack saw, cutting disc for drill, etc.
    Metal file for smoothing cut ends
    Something to pad the contact points on the car's existing rails - I used heat shrink tube and inner tube rubber.
    Something to cap the bar ends (so no one gets hurt).
    Non-permanent Loctite or double up on nuts in key locations.
    Any custom attachments you need to fit your toys.
Step 2: Cut to Fit
1. Slide heat shrink tube over u-bolt and shrink with torch, heat gun or in my case, a tea light.  The tube would not make the square bend of my u-bolts so I cut shorter pieces and convinced one to make the bend with pliers.
2. Cut your channel to length.  I clamped mine to the car roof and had a neighbor hold the free end while I made the cut.
3. File the cut end to square it off and remove any burrs.
4. Clamp cross bar down with u-bolt making sure that all metal to metal contacts are protected.  In addition to heat shrink tube I used a cutting from bicycle inner tube.
Step 3: Attaching Toys
Why I liked the spring nuts...
1. Cam action means no wrench is needed to hold the nut.
2. If you keep the spring (I took some of mine off) then the nut stays happily in the channel waiting until you need it.
3. Nuts fit some factory pick-up truck bed attachment systems perfectly too.  Slid right in to my neighbor's Nissan set up.
