Introduction: Halloween Cupcakes With Multiple Designs
The following will be instructions on how to make Halloween cupcakes with images and recipe's. Spider Cupcakes, Mummy Cupcakes, Frankenstein Cupcakes, And Monster Cupcakes.
You will need the following supplies to make your base cupcakes:
  • A large mixing bowl
  • 3 eggs
  • Vegetable Oil
  • Water
  • Cake Mix
  • Mixer
  • Cupcake pan
  • Cupcake liner
Step 1: Making the Cupcake Batter
1st mix the eggs, water, and vegetable oil together in the mixing bowl. 2nd mix in the cake batter.
Step 2: Baking the Cupcakes
pour the batter into Cupcake Liners and bake in the oven for 14-19 minutes at 350°
Step 3: Frosting/Decor
For frosting/decor you will need the following supplies:
  • Wilton Frosting Tips
  • Wilton Decorating Bag
  • Cupcake
  • Separate bowls to mix food coloring and frosting in
  • Betty Crocker chocolate and white frosting
  • Food Dye
  • Eye Ball Sprinkles
  • Rolo's
  • Black Licorice
  • Chocolate Sprinkles
  • Tooth Picks
Step 4: Frankenstein
Use a base layer of green then use the chocolate frosting for hair and a mouth. add the eyes and use a tooth pick to stick Rolo's to the sides.
Step 5: Spider
Use a base layer of black then use chocolate sprinkles over the black frosting. Add eyes on top then use tooth picks to stick black licorice on the sides for legs
Step 6: Mummy
Put stripes of white frosting for the mummy wrapping leaving a spot for eyes then add the eyes in that open spot.
Step 7: WereWolf
Put little "hairs" of chocolate frosting all around the cupcake and put a Rolo in the middle for a nose. Then add two eyes and use more chocolate frosting and some black to make ears and a mouth then use white frosting to make teeth.
Step 8: Monster
for the monster use any color frosting and using the Wilton Star Tip cover the whole cupcake in stars then add eyes on top.
Step 9: Thank You
Thank You for making or considering my cupcakes!
