Introduction: Hand-held Compressed Air Gun/Launcher
Once or twice in your life you might be lucky to come-up with an original idea. I really thought that this was one of mine. The use of a sprinkler valve as an air release is a really cleaver idea and this I borrowed. It was the hand pump in the end of the gun itself which I thought made it one of a kind. Unfortunately a quick search in Instructables revealed that another clever soul had already come up with it!
The only thing that I can claim is using a hand pump and a sprinkler valve together to make an awesome, hand-held, self-contained, compressed air gun which is easy to make and loads of fun.
So what can you shoot with it?
Rockets
paper rockets - check out the YouTube clip below to see how to make these. They may be made of paper and tape but they can really fly. Check step 10 to see how they are made
Plastic Darts
These things fly. The "bullet" consists of a plastic tube and a rubber cork. Check out step 11 to see how they are made
Paint Balls
This is why I originally designed this gun. Unfortunately these arn't easy to come by in Australia. Once I do get my hads on some I'll post a video.
CAUTION: Please be careful when using this gun. It really is quite powerful and could do some nasty damaged. Make sure that you teach any kids using this gun how to handle it correctly.
UPDATE - Check out
Step 1: Step - 1. Things to Gather
Gun
1. PVC pipe and connections
2. PVC pressure pipe 40mm (length 600mm)
3. PVC pressure pipe 15mm (length 600mm)
4. Coupling 40 x 25
5. Coupling 20 x 15 (other end of pump)
6. 40mm Cap (for handle)
6. Bush 40mm to 20mm
8. PVC Tee 40mm
9. PVC Press Faucet Socket #18 20p x 20 female
10. Bush # 5 - 40p x 25p
11. Bush # 5 - 25p x 20p
Other Bits
1. Small hand pump
2. Sprinkler valve
3. plumbers tape
4. 2.PVC Pressure cement
Tools
1. Drop saw
2. Hot glue gun
3. Black matt spray paint
Step 2: Step - 2 Design
The best advice that I can give to you is to make sure you have all the correct parts before you start. You might have to change some of the dimensions to suit your hardware. You might have to use a different sprinkler valve or pump depending on what you can get your hands on.
Step 3: Step - 3 Let's Get Started
1. Gather the parts below together
2. Cement the small bush into the adapter
3. Cement the small bush into the larger bush
4. Cement the adapter and bush into the 40mm pipe
Step 4: Step 4 - Preparing the Sprinkler Valve and Attaching.
For those who don't know what a sprinkler valve is - here's the low down. The valve is used in sprinkler systems that use a timer that switches on the system periodically. The valve itself has a relay which opens as soon as a current is activated. The valve opens virtually instantaneously so the air compressed inside the chamber is released in one huge rush.
1. On the valve that I purchased I needed to remove the flanged end to enable the 15mm adapter to be attached. I used a grinder to remove this.
2. There is also a small metal filter in the other end of the sprinkler valve. I also removed this to allow for better air flow.
3. Next wrap some plumber’s tape around the thread to ensure an air-tight fit.
4. Install the sprinkler valve into the first part of the air chamber you just built.
Step 5: Step 5 - Attaching the Tee Section
- Cement in the first part of the air chamber that you just built into one of the ends of the tee.
- Cut a 100mm piece of 40mm pipe and cement this into the bottom of the tee. This is your handle.
- Cement into place the 40mm cap
Step 6: Step 6 - Adding the Rest of the Air Chamber and Pump
1. Cement in the 220mm piece of 40mm pipe to the other end of the tee.
2. Cement onto the end of the 40mm pipe the 40 x 25 coupling.
3. Cement the end of the pump into the 25mm end of the coupling. The size of this coupling will depend on the size of the hand pump you get. A good idea is to purchase your air pump and take this into the hardware store to make sure you get the right size coupling. The pump that I used was a small ball pump.~
Step 7: Step - 7 Making Barrels to Attach to the End.
1. Gather the following parts:
- 15 bush (this goes onto the sprinkler valve)
- 15mm coupling (one for each barrel)
- 15mm coupling with male end (one for each barrel)
- 15mm coupling with female end (this goes onto the sprinkler valve)
- 15mm pipe (barrel)
- 20mm pipe (barrel)
- 15mm x 20mm coupling (used to add the 20mm barrel)
Steps
1. Cement the 15mm bush to the sprinkler valve
2. Cement the 15mm female to the bush.
3. Cement the 15mm male coupling into the 15 mm coupling
4. Cement the combine 15mm male/coupling into the barrel
Now your ready to screw the barrel into the sprinkler valve.
Step 8: Step 8 - Attaching the Trigger and Battery
- gather together the parts below.
- 9 volt battery
- momentary switch
- on/off stitch
- project box
- some wire
- cable ties
- 15mm bush
2. The first thing to do is to add the momentary switch to the handle. To do this I glued the switch into a 15mm bush and wired some wires on each of the terminals. Next I made a couple of slits in the end of the bush so I could put a cable ite through them and attach it to the handle.
3. Add an on/off switch to the project box.
4. Next thing to do is to wire the spinkler valve, switches and battery altogether. Below is a diagram so you can see how this is done
5. Cable ite the project box to the gun.
THAT'S IT! Now it's time to make the projectiles :)
Step 9: Step 9 - Shooting Stuff
So hopefully you have now been inspired and want to build your own. I have tried to give you as much detail as possible but this is really just a guide. You might not be able to find the exact same parts but this ible' should help you on your way to making one wicked air compressed gun.
What I would have done differently?
- I would have liked to have put the battery on/off switch and momentary switch in the handle and would have hid the project box.
- Adding the bush to the end of the sprinkler valve worked ok but it would have been better to have found something that fitted better. The barrel is just the slightest bit bent because the bush doesn't sit flush on the valve
- Putting the momentary switch in a 15mm coupling worked well but I would have liked this to have sat flush against the handle. This would have meant cutting 2 sides of the end of the coupling with slight curves. I did try to do this but its not flush.
So that’s it. Enjoy and remember to be safe - this is a weapon after all.
Step 10: Step 10 - Making Paper Rockets
Things to gather:
1. A4 paper
2. Tape (I used masking tape for my rocket)
3. Scissors
4. Pen
5. Ruler
Notes:
- Make sure that the rocket isn't too tight fitting around the barrel. The smoother the better.
- Make the nose-cone strong. This is the part which will take the most damage.
- Don't forget about the cap at the top of the rocket where the nose cone goes. Without this the rocket will most likely break at the join.
To see the rocket in action check out the YouTube clup at the start of the instructable.
Step 11: Step 11 - Plastic Bullets
so here's what I did.
1. First I found some pipe that fitted perfectly down the barrel. I was lucky enough to find some at a bargain store selling halloween products, one which was a pitch-fork with a plastic pole!
2. Next I cut the pipe in different lengths and tried various ones to see which would work the best. I found That a peice of pipe about 150mm worked best as it was stable and went the furthest.
3. Next a got some rubber corks and stuffed one down the end of the pipe. Make sure that the cork is right down in the pipe so when put into the end of the barrel the fit makes the bullet just stick. This will eleviate the friction which will make your bullet go further.
Check out the YouTube clip at the start of the Instructable to see it in action.
Step 12: Setp 12 - V2 Bigger and Better
Batteries - Instead of having a cable-tied box on the gun itself, I now have them in the handle. It was a little tricky but you can see from the PDF image below how I managed to do it. It also has 2 9v batteries instead of just one. I was finding that if I put too much pressure in the air chamber the sprinkler wouldn't activate.
Pump - I used a much better quality pump this time and have also made it removable so when it finally fails I can just replace it.
Sprinkler Valve - I un-did the valve and turned it around so the wires were facing down the gun and not going sideways (see image)
Images to come soon.
