Handmade Platinum Engagement Rings
Intro: Handmade Platinum Engagement Rings
Since my day job is making jewelry I figured I'd show a few engagement rings I've made. These are entirely hand made from Platinum.
The first ring was an especially challenging job as the opening in the the side of the ring is only 8mm wide. The vine sections are made from fourteen separate Platinum pieces. Platinum wire that is .07mm thick (about .003 inch) is used for the vines and the leaves were cut from Platinum sheet, hand engraved and welded to the vine sections. The assembled vine sections were then inserted into the 8mm wide opening and then welded into place from the back side. It's a very small ring- to put in in perspective the side stones on the top of the ring are 1mm in diameter.
The next two rings are entirely made from Platinum sheet and wire- no castings were used and there are over forty soldered joints in each ring. To make rings like these I start with the center head by forming the prongs and gallery wires, bending them to shape and joining them together. The prongs and gallery wires for the side stones are then added, paying close attention to the stone spacing. The ring shank is then hand forged, shaped and attached to the head assembly. The ring is then pre polished and the stones are set and then the detail work/hand engraving is done, followed by the final polish.
One of my happiest moments at work was when a woman picked up her custom ring and turned to her little girl and said "One day this will be yours."
69 Comments
danadams 8 years ago
Honus 8 years ago
Here's a new one for you-
https://www.instructables.com/id/Hand-Fabricated-En...
If you have any questions just let me know!
j25dean 9 years ago
Your rings are beautiful.
Honus 9 years ago
Mary Suu 9 years ago
Finally, I get the birthday gift for my girlfriend. :D
AndrewCampbell 11 years ago
You certainly seem to have a gifted pair of hands, to produce such diamond rings with such detail is very difficult. Thanks for showing us your capabilities.
Honus 11 years ago
jthej 11 years ago
I do see the seams. Sorry for busting your chops. I some how ended up on this site and saw the work which is nice. So many people say they do hand work in platinum and simply they don't. Too many people today think customizing is buying a shank then putting the appropriate head on for the customers stone and say the ring has been customized!! Suggestion, with platinum, you don't have to do a lot of pre polish, just keep everything clean along the way. Finishing difficult places can be done with polishing stones and a fine burnisher similar to what a dentist uses. The engraving on the shank should be either done at the end or should be touched up at the very end (including beading) to make it "pop". For "bright" cuts with the engraver, after sharpening, polish the graver tip on high quality crocus cloth. After you get the hang of it, your graver makes really bright cuts that are quite beautiful. Nice job.
Honus 11 years ago
We joke about that all the time at my work. I really dislike the term "customized" (as does the other jeweler I work with.) Buying pre made parts from a supplier and soldering them together isn't true custom work- it's assembly work. There's nothing wrong with that if that's what someone wants but it's not the same thing as true custom work. There's also a big difference between "hand made" and "hand fabricated." Hand fab jobs for me mean the entire piece is fabricated from sheet and wire metal stock- no castings or pre formed parts are used. I used to do a lot more hand fab jobs than I do today. This ring is what I would call a hand made custom ring but it most certainly is not a hand fab job-
https://www.instructables.com/id/Platinum-engagement-ring-from-CAD-to-finish/
I've never used crocus cloth to polish graver tips before. I've only used a ceramic wheel with a diamond spray. Thanks for the tip- I'll have to try that out. When doing hand fab platinum jobs I typically only pre polish the areas that will be hard to access later. I'll also often use a split lap to get the sides of a ring nice and flat before soldering heads on so I can get a really nice final polish later, especially on designs that have a halo style setting since it can be really difficult to access the area under the halo once it's attached to the ring shank.
I made the two rings in the lower pics around fifteen years ago and that was probably the first hand engraved ring shank I had ever done- lol. If you want to see some really amazing engraving look at the work done by Amayak Stepanyan. I met him a while back and got to see some of his work up close in person and it's truly amazing. I'd love to take one of his classes. Super nice guy too.
jthej 11 years ago
I was curios because under the rings and inside the ring in the three lower pictures, I don't see either saw blade marks or file marks only what looks like casting porosity. On the sides I don't see typical bright cuts which you would have if it were done with engravers, so I am curious how you made it with out filing or sawing or engraving?? Thanks!
Honus 11 years ago
The reason you don't see typical bright cuts or file marks or saw blade marks is because of the finishing/polishing work I do as I construct the ring. When hand fabricating with Platinum I do an awful lot of pre polishing before I solder joints.
jthej 11 years ago
Honus 11 years ago
That's not porosity from casting- I can assure you that bottom section was made from a flat sheet of Platinum rolled in a rolling mill. It could be that is polishing compound. After rolling the piece out it was curved to match the inside ring size dimension. Then the cutouts were cut with a saw blade, cleaned up with a knife edge graver and then polished using a round toothpick loaded with Platinum polishing compound.
I have a custom hand fab Platinum coming up soon at work- the entire ring will be made from sheet and wire. I'll be happy to document the entire process from start to finish so you can see how it's done.
jthej 11 years ago
A question please, how do you describe the parameters of "hand made"? Does it include casting or does it have to be100% hand formed and saw piercing every opening in the metal and 100% hand engraving every detail and relief cutting for deapth in the filligree? Thanks!
Honus 11 years ago
mishyoyo 11 years ago
Honus 11 years ago
lukish 12 years ago
https://www.instructables.com/id/Inexpensive-Homemade-4-Band-Puzzle-Ring/
Honus 12 years ago
lukish 12 years ago
