Introduction: Hands Free Photography With a Smart Phone
I make pop-up cards, and, since I like showing others how to make them too, I shoot videos of my hands cutting, folding, and gluing.
My phone is by far the quickest and easiest camera for making web quality videos, but there are surprisingly few phone tripods on the market. I wanted a mount which I could easily adjust and put right by my face as I work, to get perfect POV shots. I can keep one eye on the screen and one on my hands, to make sure they stay in the frame and in focus. The footage shows the pop-up being made as you would see it, which makes it easier to follow.
Possibly, if I'd spent lots of time looking, and lots of money to buy and ship it, I could have found a ready-made solution manufactured half way around the world. Instead, I rummaged through my recycling bin and my pile of lamp parts (collected while walking my dog on garbage day), and rigged this up in about 15 minutes. A quick and dirty job. It might not be pretty, but it was free and works like a dream.
Step 1: Materials & Tools
This is the list of the parts I used, but since looks don't matter here, I encourage you to use whatever you can find in the trash: don't buy parts if you can re-use something which is going to be thrown out....
A weighted lamp base
A gooseneck pipe (24" is ideal)
A fixture crossbar (for attaching the gooseneck to the lamp base)
A tin can (14 fluid oz or 414 ml)
A pipe flange with a female threaded hole or a hickey to attach the gooseneck pipe to the tin can
A couple nuts and bolts (for attaching the hickey or flange to the tin can)
A rubber band
The only tool you'll need is a drill to make small holes in the tin can where you will be attaching the flange or hickey.
NOTE: you can also skip most of this and just use an existing adjustable table lamp, as long as it's strong enough to hold the weight of a phone.
A rubber band
Step 2: Assembly
Attach the lamp base to your gooseneck pipe by threading the crossbar on the pipe through the hole in the lamp base.
To attach the tin can, drill small holes towards the middle of the can, where you will be bolting your flange or hickey (a flange is better, but I used a hickey because that's what I had on hand). Use your nuts and bolts to attach the can to the flange, then screw the whole thing onto your gooseneck pipe.
Done!
NOTE: Theoretically you could also skip the flange, drill a slightly bigger hole, and attach the tin can directly to the gooseneck pipe with a nut on the inside of the can. I chose not to do that because I was worried that it would stick out too much inside and might get in the way of the camera, but I'm sure it could work too.
Done!
Step 3: Use
Put your phone into the tin can and use a rubber band to make sure it doesn't slip out when you adjust its position. Sometimes I'm lazy and I neglect this step, and though I've never broken my phone there have been some close calls... The phone has never slipped out with the rubber band in place.
To adjust the lamp, make sure you hold the top of the gooseneck pipe and NOT the tin can, or you might bend the tin.
