Introduction: Heart Attachments for Draculaura
This is for a tutorial on how I made my heart attachments for my Draculaura belt!
Fusion 360
Ender 3 printer
3D Filament
Step 1: Create the Heart Shape
First step is to create a heart shape. You need to open Fusion 360 and create a sketch. Then you will make two circle sketches to make a ven diagram. After you have that shape, add two lines from the outside of both circles, creating a triangle shape underneath the ven diagram. The you will want to use the fillet tool on the bottom of the triange to make it rounded. Finally delete any extra lines
Step 2: Making the Heart 3D
Once you have your finished heart sketch, use the pipe tool to create a 3D heart. Finally, use the hole tool to create an opening on the top of the heart, changing the size of the circle based on how big you want it. Make sure the top and bottom of the heart are both closed
Step 3: Printing the Heart
Now, you will need to export your heart as an stl file and upload it to Ultracura, or whatever software you use to connect to your 3d printer. I used an Ender 3 printer at a 25% infill and printed out 6 hearts
Step 4: Finishing the Heart
With your finished hearts, you just need to take a sheet of sandpaper, and sand the heart to make it nice and smooth. Then, prime with a white base and paint. My hearts used a white filament, so i did not need to prime, but i used a pink spray paint with a glitter spray paint on top and was done!
