Introduction: Hidden Blade
A working Assassins creed hidden blade
1 hidden blade
1 spool of double-sided velcro
1Glove
1 wrist cover
Step 1: Add the Hidden Blade to the Brace
while adding the blade to the brace place it in the middle and hot glue it to the brace
Step 2: Dill a Hole in the Mechanism and Feed a String Through It
After feeding the string through the hole you drilled. after you feed the string through attaching a button to it so if you pull on the string the button pushes the button.
Step 3: After Doing This Feed Velcro Throw the Slots on the Sides
this will go around your forearm
Step 4: Now Attach It to Your Forearm and Add a Middle Velcro Strap
Step 5: And Now Your Done
some of the problems are it won't pull all the time
and it will shake a bit
