Introduction: Hide It Teddy
How to make a hide it Teddy to hide all of your valuables
supplies needed are a hot glue gun or Elmer’s glue, a old teddy bear, a pair of scissors and a jar of any sort
Step 1: Finding Supplies
Gather supplies, supplies needed are a hot glue gun or Elmer’s glue, a old teddy bear, a pair of scissors and a jar of any sort
Step 2: Plugging in Hot Glue Gun
Plug your hot glue gun in so it is ready to be used when needed. TIP- Put it on a cutting board so the glue doesn’t get on your flooring or workspace.
Step 3: Removing Head
Remove the head of your desired stuffed animal using a pair of scissors. You will remove the head by cutting the seam connecting the head to the body.
Step 4: Remove Stuffing
Remove 1/4 of the stuffing from the head and body leaving room for your jar and lid. TIP- The bigger the jar the more stuffing you will need to remove
Step 5: Putting Jar Inside
Put the jar inside the body of your stuffed animal, you will not need to glue it because it is friction fit. That means the jar is tight to the body of your stuffed animal and will not move. TIP- You may need to add or remove stuffing as you go.
Step 6: Glue Lid
Put glue around the rim of the jar lid and insert into the head of your stuffed animal. You may need to add more glue to make it secure
Step 7: Filling Bear
Fill with your desired filling. ( I used money!)
Step 8: Done
