Introduction: Hippie Inspired Feather and Beaded Ear Hook
This is a feathery beaded ear hook.
It's very easy to make and yet it's stylish.
The colors of the beads helps you to match the ear hook to any of your outfits and it never goes out of style.
I hope you all enjoyed this project and have fun making one yourself.
Step 1: Prepare Materials
For this project you'll need:
- Feathers. (Don't pluck any of your domestic animals).
- Pliers.
- Beads
- Super Glue
- Wire.
Make a coil of wire. Make it about 1-1.5 cm smaller than the end of your feather's hollow shaft.
Now make some jump rings.You can learn to make jump rings from the link below.
https://www.instructables.com/id/How-to-Make-Jump-R...
Make a loop (as shown in the image no:3).
Step 2: Prepare the Feather
Put a bead through the hollow shaft.
Then put through the coil,
and lastly put the loop in the spring.
Now use super glue to stick the hollow shaft,coil and loop together.
You can glue the coil and loop together before pulling it through the hollow shaft.
Step 3: Join
Wire some beads as shown in the image.
You can learn to do this from the link below.
https://www.instructables.com/file/F4XLSKQHOPQDGX2
First put a jump ring through the loop.
Then put the wired bead in the jump rind.
Keep doing that until you get how long you want your earring to be.
When you'be reached your last wired bead attach a ear hook to it.
And ta-da the ear hook is done.
