Introduction: Homemade Annoy-a-thing (Annoy-a-tron)
Thinkgeek.com sells a thing called an annoy-a-tron. Its basically a device that, when activated, beeps at a varied interval. While this instructable does not create an exact replica of think geek's annoy-a-tron, if you've got the materials and the know-how, you can make quite a few and deploy an entire fleet of them! :D
(please note that this is not an instructable on soldering or electronic components. prior knowledge is assumed)
Step 1: PARTS!
YOU WILL NEED:
PARTS:
- 20k ohm resistor (red, black, orage)
- 10M ohm resistor (brown, black, blue)
- 10 uF capacitor
- perforated circuit board
- CMOS 555 timer (MUST be cmos / low power consumption to run on a 3v battery!)
- diode
- 3v battery (2032) & battery holder
- asst. lengths of wire
- mosfet (i use a VN10KM, others may work)
- piezo buzzer (apply current and get a beep, just the piezo element itself will not work for this)
- solder
- switch
TOOLS:
- soldering iron
- wire cutters
- box cutter or exacto
- knowledge of soldering and electronics :D
Step 2: Nitty-gritty
the circuit diagram is shown below. hopefully it is readable.
if you've got a breadboard, lay one out first and make sure it all works!
AGH sorry! Revised schematic 4/4/09(thanks dad)
Step 3: On Perf Board and Component Leads
you can find perf board online or at places like radio shack. its really handy, and you can use an exacto or a box cutter to score along the perferation and break off pieces you need.
my project here is 11x9 holes. depending on the size of your components and your layout, your size my vary.
another good idea is to lay out your components before you cut (to know how much you need) as well as after you've cut it. knowing where things go before you start speeds up the process and prevents having to go back.
one last tip: when cutting off excess component leads, you can save them and use them to make connections to the bottom of your board.
Step 4: Final Thoughts
after you get all of your components onto your board, the bottom work begins. i try and lay the circuit out so many of the connections can be made by jumping between two adjacent holes with solder. i find the most difficult set to be the underneath work, as it requires steady hands and more thought.
hopefully all has gone well and your annoy-a-thing works! this set up i've just layed out should last about a month.
as with all little projects like this, a magnet can be added to the bottom. this will, however, add thickness, so i prefer using double sided sticky tape.
one of the things think-geek's annoy-a-tron has that this one lacks is a different length of time between beeps. this particular "annoy-a-thing" will beep about once a minute (+/- a few seconds depending on battery life).
ALSO: note that you can change the time between beeps by changing the value of the 10M ohm resistor. if i'm not mistaken, i believe a value of 20M ohm will make it 2 minutes, 30M ohm is 3, so on. (you wouldn't want to go too crazy and make it 10 minutes or something, i don't think that would work. but hey, nothing stopping you from trying!)
your comments are appreciated!
