Introduction: House Incense Holder
Hi All,
In this instructable, I will share how to make an incense holder using cement... You can use this as an incense holder, or in miniature, landscaping or terrariums
- Foam board
- Cutter
- Steel Scale
- White cement
- Popsicle sticks
- PVA glue
Step 1: Mold 1/2
- Draw a house on a foam board, as shown
- Mine is 5 cm at the base and a height of 7 cm
- Cut a piece of form board to leave approx 1 cm
- Stick the two pieces together using superglue, as shown
- Make another copy of this
- Cut 2 pieces of foam board 3.8cm x 6cm for the side walls
- Using superglue stick all the walls
- Add a base too
Step 2: Mold 2/2
- We need a cavity inside, for which I have used styrofoam
- Again leaving 1cm margin on the sides and top
- Stick the styrofoam to the base
- Cut two pieces for the roof, but glue only one in place
- We will use this opening to pour cement
Step 3: Cement
- Make a thick mixture of white cement and water
- Pour it into the mold, rotate the mold at an angle, and place it in a bowl
- Fill the cement untill the brim and cover using the last roof piece
- Leave it to dry for 10 hours
- De-mold it gently
Step 4: Cleanup
- After demolding, soak the house in water for a day
- Superglue reacts with cement and leaves rust-like marks
- Use cement slurry to fill any holes and cover these marks
- Drill a hole for the chimney using a screwdriver
Step 5: Detailing
- We will use (20mm wide) popsicle sticks to make a door and a window
- Using the same popsicle sticks to make the chimney
- Use wood or PVA glue to stick the door, windows, and chimney in their position
- Let this dry for 2 hours
Step 6: Finalizing
- Light an incense stick and place the house on it
- The smoke should come out of the chimney
- You may have to drill some air holes at the base for airflow
- And use super glue to fill any unwanted leaks
- Once done we can set it on a shelf and admire it's beauty
- Optional : make a cement disc to avoid burn marks on the self
I hope you like and make one
