Introduction: How I Made a Plant Swing Holder
Paul Fleck
4 pieces of 60 inch rope
1 primed finger joint board 1/8/8
4 all purpose hook
Step 1: Measurements
Measure the size of your window frame. Mine was 14in by 7in by 60in.
Step 2: Cutting the Ropes
Measure your window from top to bottom. My window was 60in long, so I cut 4 pieces of rope 60in long.
Step 3: Cutting the Board
I made the board a little smaller than the length of the window frame, so I can fit part of it into the frame. So I made my board 13.5in.
Step 4: Making Holes in the Boards
Make a hole in each corner of the boards. I clamped all of the boards together so then I only needed to make four holes through the boards.
Step 5: Putting the Rope Through
Put the ropes through all the holes in the three boards. When done putting a rope through a hole, tie a not under the board. This second part is optional because its just for design: when done putting all of the ropes through the holes and tying them, then loop the board through it's rope to get a twisted design.
Step 6: Putting Hooks on Window Frame
Put the hooks on the top of your window frame. This will hold up the boards and rope.
Step 7: Putting It All Together
Now just tie the top ropes to the hooks and then put plants on it or what ever you want.
