Introduction: How to Change Lawn Mower Oil
About: We are the ULTIMATE in supplying you with replacement parts from over 60 name brands, and creating award winning How To Articles and Repair Videos. eReplacementParts.com is #1 when it comes to figuring out e…
This article and its video explain how to change lawn mower oil on most mowers, and how to change oil filters on mowers that have them.
The small engines that run lawn mowers need their oil changed just like car engines. Most mower engines need their oil changed every 20-50 hours of operation.
A mower's owner's manual will indicate how often to perform oil changes on the mower. At the very least, an oil change should be done annually with other seasonal tune-up maintenance.
This article explains the steps for changing oil in most mowers. Changing mower oil is very simple and can take as little as five minutes.
Step 1: Prepare for the Oil Change
There are a few things to do before removing the old oil from the mower.
1. Warm up the engine
Warming up the mower engine will speed up the oil change because the oil will flow more freely. It will also be a little easier to get all of the old oil out of the engine.
2. Clean around the oil fill area.
Use an air compressor or a clean towel to clean up around the oil fill area
3. Prepare an oil pan to catch the oil.
You'll need an oil pan or something similar to catch the oil from the mower. Position the pan on the side of the mower towards which you will tip it to drain the oil.
Step 2: Dump the Old Oil
Now with the prep work done, the mower should be ready to have its oil drained.
4. Remove the oil fill cap.
5. Tip the lawn mower on its side to drain its oil.
It's a good idea to leave the mower resting on its side for about a minute while all of the old oil drips out.
Tip Lawn Mower
Step 3: Replace the Oil Filter (if Applicable)
The majority of walk-behind lawn mowers do not have oil filters, but several models on the market include them in the engine design. We've included the steps for changing a mower's oil filter below in case your mower model includes one.
If your lawn mower engine model does not include an oil filter, skip to step Step 10 to complete your oil change.
6. Prepare something to catch the oil.
Unscrewing your mower's oil filter will spill the oil it is holding inside of it.
Container to Catch Oil
Find something to catch the oil that is small enough to fit under the filter as you unscrew it.
Postion Container
7. Unscrew the old filter.
The old filter simply unscrews.
8. Coat the seal of the new filter with oil.
The seal of the new oil filter needs to be coated with oil before it is installed.
Using your finger, apply a small coat of motor oil to the outside lip of the new filter. This thin coat of oil will ensure that it seals tightly when you install it.
9. Install the new oil filter.
Screw the new oil filter into place until it touches the plate it seals against. Then, give the filter a firm 1/4 or 1/2 turn to tighten it down.
Step 4: Refill Mower Oil
Now the mower is ready to have its engine oil refilled. Remember that over-filling the oil on a lawn mower engine is just as bad as under-filling it.
Check the mower owner's manual for the exact quantity of oil that the mower takes.
Use the mower's dipstick as the final judge on the right oil level. Most mowers take between 2/3 and 3/4 a quart of oil
10. Add engine oil gradually until it is full.
Fill Engine Oil
Stop a couple of times as you fill the oil to check its level with the dipstick.
Creeping up on the "full" line like this reduces the chance of overfilling.
11. Replace oil cap.
Your lawn mower oil change is now complete.
Conclusion
Changing your lawn mower's oil will help its engine run powerfully and dependably. This and other simple equipment maintenance will greatly extend the life of your tools.
eReplacementParts.com can help you with your lawn & garden machine repairs. Visit our Lawn Mower Parts page to shop for parts by mower brand, or visit our Small Engine Parts page for more small engine maintenance parts.
