Introduction: How to Drill Straight Holes With a Hand Drill (Using Lego)
If you've ever tried to drill a straight hole with a hand drill you know how hard it can be. After screwing up drilling a hole three times in a row I decided to try to find a solution to the problem. This is what I came up with. The great thing about using Lego for this purpose is that you don't have to spend a lot of time making this jig; you just snap the pieces together and get to work. As with any project, be sure to use the appropriate safety equipment and be careful!
Thanks to everyone who voted for me in the Fix & Repair Contest!
Step 1: What You Need:
- 9 4x2 stud bricks
- 3 2x2 stud bricks
- A right angle protractor (just to double-check the jig)
Step 2: Building the Jig
- Start by arranging 3 2x4 bricks and 1 2x2 brick into an "L" shape.
- Build up from that shape, covering the seams where the bricks meet on the layer below. You will have a 3 layer right angle when you're done.
- Use the protractor to make sure the jig forms a right angle.
Step 3: Using the Jig
- Hold the jig down against the wood the same way as in the pictures. Position the drill bit tightly in the corner of the jig and drill the hole.
- The bricks might get marked up a bit after a while; if that happens, just swap them out with new ones!
