Introduction: How to Make a Light Necklace
In this i will be showing you how to make a light necklace using...
An LED Christmas light
Tape
A button batterie
And string
Tape
A button batterie
And string
Step 1: Take a Light From the Christmas Lights
To take out a light pull the tab.
Step 2: Take the Light Out
Pull the plastic/glass tip off and pull the metal prongs down. Then all you have to do is pull out the light.
Step 3: Tape the Light to a Button Batterie
It dose matter which side the metal prongs are on
Step 4: Tape the Light on
Once you find the position that it glows tape it on.
In some positions it can be like a flashlight. The light will go on when you press it.
Step 5: Put on the String
How I put on the string was taping it. If you know a better way go for it.
Step 6: (optional) Cut Out Two Paper Circles Smaller Than the Button Batterie
If you want cut out two paper circles a little bit smaller Than the batterie decorate them at tape them on.
This light will stay on for a very long time. If it goes our just replace the batterie. It's that simple.
Step 7: Thanks : )
Thanks for reading.
