Introduction: How to Make a Model T-600 Terminator Costume
The final costume includes a minigun, a light-up red eye, a backlit chest, and various parts of the endoskeleton.
This project took a lot of time to make (20+ hours), but it is relatively inexpensive (about $60-$70). So far this has been the most fun thing I have built!
Step 1: Materials
*Military Surplus Camo Jacket- $5
Camouflage Pants- $15
Grey Undershirt- $5
1/2 Inch PVC Pipe- $5
Beanie- $1
Batman Mask- $5
Spray paint in Black, Green, and Silver- $15
**Liquid Latex- $16
I bought the following items for All Electronics Corp.
1/2 in Split Loom Tubing 15ft.- $2.50
***LMP-12R Red Lamp- $1
Red LEDs- 10 for $1
3 On/Off Switches- 3 for $1
WR-19 Velcro- $2.50 per pack
I wasn't sure how much I was going to need, so I ordered three packs.
Two packs will be fine.
I found the following materials at home.
12v LED (3x)
Small Section of 3 inch PVC Pipe
Black and Silver rolls of Duct Tape
Corrugated Plastic
Cardboard
Duct Tape (Black and Silver)
18 AWG wire
9v Battery Snaps
Mailing Tubes
Grey Knex Rods
Tools:
Hot Glue Gun
Soldering Iron
PVC Pipe Cutters
Sharp Scissors
Hack Saw
Sander of any kind
*This was more of a lucky find at Goodwill. The shirts will cost about $25 at a military surplus store.
**This was the monster 16oz. bottle, but a small 4oz. tube will have enough liquid latex. The smaller tube will also cut costs by about $11.
***It is VERY important to buy the EXACT same lamp in order to have an eye with the right pattern.
Step 2: Make the Endoskeleton Chest
First, cut out the pieces using the measurements below, and glue the pieces together like in the second picture. I used hot glue for this due to the fact that it cools off quickly, but, if you have the extra time and patience, you could use epoxy.
-The top piece is 95mm by 79mm.
-The next lowest piece is 95mm by 105mm.
-The bottom middle piece is 95mm by 95mm.
Step 3: Chest Cont.
For the following steps you need to cut out multiples of these pieces:
Step 4: Chest Cont.
Step 5: Chest Cont.
Step 6: Chest Cont.
Now, take the duplicate of the bottom middle portion of the chest, and cut out the pattern below. Cut the inside of the shape using the tip if the scissors like in the next two pictures. The edges will be rough, but the hot glue will even them out.
Ignore the circles on either side.
Step 7: Chest Cont.
Step 8: Putting the Chest Together
First, cut out six small triangles from squares of corrugated pastic 10mm wide. See the picture below.
Glue the portion from step five to the triangles and the to the basic chest piece like the second picture. Also glue on the bottom middle piece with the spike things pointing towards the top of the chest.
Next, cut out a rectangle that is three flutes wide and 80mm long. Cut two sides off of one of the flutes on the side, and glue it on like in the second picture.
Finally, glue the wings on, and add glue to and rough edges. The final corrugated plastic portion of the chest should look like the third picture and like the T-600 figure.
Step 9: Adding Split Loom Tubing
I glued the tubing to the chest with a generous amount of hot glue for added strength. The middle tube was long enough for me to use only one section across the whole chest, but it later caused problem with mounting the electronics in the middle of the chest.
Also, glue the split in the tubes together with little drops of glue every inch or so.
Make sure there is enough room for switches on either side of the chest. Put them wherever you want.
*Something I forgot to take a picture of is two more tubes glued on the length of the bottom. The tubes were glued on top of each other, so when the chest is put on the bottom sticks out like it should.
Step 10: Adding Velcro
First, you need to take the velcro straps from All Electronics and undo them.
Next, cut the hook part of the velcro off and glue on the straps so the loop part of the velcro is on the inside. Glue both sides of the strap to the chest since it will need to withstand lots of pressure. Do this to both sides.
Another strap is used in the back to fasten the chest plate to the wearer. This can be seen in the fourth picture.
Save the painting of the chest until after the eye portion is done since they are both connected.
Step 11: The Eye
This step, although the quickest, is the hardest to do. This is why I bought three lamps instead of one. Fortunately, I only ended up with a tiny, unnoticeable crack in the first one I tried to cut to size, and I was able to use it with the crack.
You need to first pull the lamp portion out of the red housing. Next, the threads need to be cut off and the square shape needs to be sanded down to a circle.Follow the picture below.
Step 12: The Mask
Next, start cutting down the edges, but leave a top portion on at the side, like in the first picture. This is for the wires from the eye. The beanie should also be able to go over that top section. I also cut the eyebrow off because of how sharply it stuck out. I then filled the gap with hot glue.
Step 13: Joining the Eye to the Mask
Next. mount the LED in the hole. I found some 12v LEDs in my electronics drawers, so I pulled one out of its housing and used it for the eye. Run the wires through the notch in the top of the mask and solder enough 18 gauge wire to the leads to run it around the back of your head and into the chest. I soldered extra wire in, just in case, and bundled it up under my beanie.
Step 14: Spraypainting the Chest and the Mask
This step is pretty much self-explanatory, but remeber to use silver for these parts. Put a piece of tape over they eye so light still comes out of it.
Also, make sure all of the front of the chest and all of the front of the mask are painted. It does not make a difference in the dark, but when people take pictures and flashes of light are present, the full paintjob makes it look nicer.
Something I did not realize until the chest was painted was that the tubing looks amazing with just a bit of black showing in between the ribs.
Step 15: Wiring the Electronics.
Next, I wired the lights in the chest. The LEDs are in parallel, and the batteries are also in parallel. The switch was located on the side for easy access, and the batteries were attached with double sided foam tape.
Finally, I wired the LED in the eye to a single battery in the center. The switch for this circuit was located on the side opposite of the other switch.
The chest and mask are now complete.
Step 16: Making the Knee
Also, since there is a big hole exposing the knee, I made a shin cover with silver duct tape. I attached velcro straps to it and reinforced it with duct tape.
Step 17: Making the Arm
For the solenoids in the arm, I just covered the grey knex rods with silver duct tape and cut them down to size. Then I taped them to the inside to the mailing tube, like in the third picture.
Step 18: Cutting the Shirt
Next, I made slash-like cuts from the left elbow to the wrist. I frayed the edges and also cut portions of it off partially and completely. This left fabric hanging from my arm. I did not cut off the buttons at the end of the sleeve because they helped me keep my gloves on. They also hide the transition from undershirt to skin.
Also, make a clean cut from the right elbow to the right wrist. This cut is used to tie the minigun to your arm.
Step 19: Cutting the Pants
At the knee, cut a Y using the same techniques used to cut the shirt. The pictures below show how I cut the knee.
Step 20: The Backback
The top is angled on the opposite side of where the belt feeder is attached.
The pack was first painted a greenish color, then black stripes and spots were added. I thought this color green was bad at first, but in the dark with the black marks, it looks great.
I attached the backpack by taping string to the side facing my back and running the string through my shirt, over my shoulders, and out the bottom of my shirt.
Step 21: Making the Minigun
First, start with the barrels. Cut a 10ft. section of 1/2 PVC pipe into five 2ft sections.
Next, trace the PVC on a cardboard circle spaced evenly around another drawn circle, like in the second picture. Do the same to a corrugated plastic disc, and cut them both out. Glue the coroplast disc 45mm from the end of the barrels and the cardboard disc halfway between either end.
Now, cut a 4 inch section of 3 inch PVC pipe and glue it to the corrugated plastic.
Step 22: Finishing the Minigun
To make the mechanisms that would drive a minigun, cut out a 9in. and a 6.5in. section of mailing tube. Use leftover mailing tube from your arm if you have any. Cut a 3 inch lengthwise section off of the 6.5 in. tube, and glue the cut side to the 9 inch section. This will be the bullet feeder.
Now trace the barrels on an endcap for the mailing tube. Glue the endcap 7 inches up the barrels and glue it to the 9 inch mailing tube. Use strips of corrugated plastic like wedges to position the barrels, and add lots of hot glue for support.
Cap any open ends by taping cardbord over them. Once all of the ends are capped, spraypaint the whole thing black.
The belt feeder consists of two 3ft sections of split loom tubing taped together every 3 inches. One end is attached to the backpack, and the other is attached to the bullet feeder.
Step 23: Putting It All Together
The first layer is the undershirt. Wear it backwards if there are any logos on the front, and cut holes in the ends of the sleeves for your thumbs. This brings the undershirt under the gloves.
The next layer is any part of the endoskeleton. This includes the mask, the knee, the arm, and of course, the chest. To attatch the mask, put liquid latex over the part of your face that the mask goes over. Do not get it in your eyes. Press the mask to that area, and wait for the latex to dry. Do not use liquid latex if you are allergic to latex.
The third layer is the shirt, the pants and the gloves. Tuck the gloves into what's left of the sleeves, and button the sleeves.
The final layer is the accessories. This includes the beanie and the minigun. To attatch the minigun to your arm, just tie straps through the cut in the arm and around your arm.
