Introduction: How to Make a Stunt Paper Airplane
Step 1: Video of It Flying
ok so here it is, you guys asked for one, ill give you one
Step 2: Materials
The only material you will need is paper.
Step 3: Lets Get Started
first, your going to fold the paper like your about to make a square.
then you do the same to the other side.
open the paper out and turn it around.
fold it like so.
then the tricky part. you are going to turn it around then touch the middle of it then it will pop in to this.(2nd last photo)
the make it into this.
fold it like so.
Step 4: Next
Now, you are going to fold the triangle part horizontal. and then do the same to the other side.
this part is a little hard and I guess .... um complex?
you fold the triangle part into the other part like so.
then, you fold the triangle on the top down.
Next, you fold it in half like any else ordinary paper air plane.
and also do the folds that make the wings.
and thats it for this step.
Step 5: The Hard Parts
Yes...They are a little hard and kinda complex.
first, you are going to make this fin thing on the back of the plane.
the hardest part of the plane ( I guess)
you have to make a front scoop by holding the plane by the front of the wings then getting the triangle thing on the bottom of the plane and slide it into a scoop.
Now, you flip the plane on its side and fold like this, then do the same to the other side
also, you make little triangles on both sides like so.
go to the fin thing on the back and make another fin on the inside, or you could just cut it off like like this, but I recommend you do the reverse fin thing.
Step 6: Almost Done
now, you are really close to done!
now just flatten the plane out a bit, and them make little ailerons by tearing or cutting with scissors.
the fold like this, put it back like this and...
YOU ARE DONE!!!!!!!!!!!!!!!
Step 7: Done!
Now all you have to do is fly it.
Have fun and be safe.
