Introduction: How to Make the Bobcat Paper Airplane
A fast, long range, and small paper airplane, the Bobcat can also prove to be a satisfactory stunt plane too.
TAA USAF Designation: A13-1
Step 1: Materials
Required:
1 Piece of 8.5 by 11 inch Paper
Tape
Optional:
Ruler
Pencil
Tape
Optional:
Ruler
Pencil
Step 2: Length and Corner Folding
Begin by folding your paper in half along its length. Then pull the corner into the center. Repeat on the other side.
Step 3: More Corner and Nose Folding
Pull the nose down along the bottom of the corner folds. After completing that aspect, pull the corners in once again. Now fold the plane in half along its center.
Step 4: Security Fold Preparation
Pull the tip of the nose to the outer-rear edge of the second set of corner folds. Then open the fuselage. Proceed to tuck the section you just folded inside, so that it reverses layers. After this is all complete, fold the fuselage back up around it. It should then appear with the same profile as it does in the first photograph.
Step 5: Fold the Wings
From the front to the back, fold the wing down as much as you can. It should then appear as it does in the first photo. Once you've repeated it on both sides, your Bobcat should appear as it does in the the second and third photographs.
Step 6: Make the Security Fold and Tape It
Pull your Bobcat's security fold down along the wing root to one side or the other. After this is completed, open it up and then scrunch it down to where it meets itself using the inner and external centers. Flatten it out, then fold the overhang down to the bottom side of the wing. Tape these two sections of overhang to the bottom of the airfoil once they are in place.
Step 7: Fold the Winglets
To make the winglets, fold the outer wing sections with the sharpest sweep up. Make sure they both remain parallel to the fuselage.
Step 8: Flight
Flying the Bobcat is very simple and easy. Throw it at medium speed, and you are going to get excellent flight. One time to be very cautious with the plane is landing. Due to its fuselage's shape, the has a tendency to lay on its nose.
Enjoy!
Enjoy!
