How to Make a Drawing Pad
weddlbel 'profile picture'
4.0K31
Intro: How to Make a Drawing Pad
This is an easy and quick way to make a drawing pad.
STEP 1: Materials
*Paper ( it is your how much) *Pencil, stick, anything straight *Rubber band or hair band
STEP 2: Holes
At the top of the paper you are using for your drawing pad you need to punch two holes big enough for whatever kind of pencil or stick you are using.
STEP 3: Final Step
Now you need to lay your pencil or stick straight across the paper. Stick one end if the rubber band through one hole and put the pencil through it. Then poke the other end through the second hole and pit the pencil through it. The rubber band should be pulled tight. It is slightly hard to pull the rubber band through but once you get it it is worth it!!!! Now you have an awesome drawing pad!!!
