Introduction: How To: PINK GLITTER SLIME
Easy-To-Make Pink Glittery Slime In Minutes! I Hope You Enjoy!
Step 1: Procedure
Approximate Time: 10 minutes
Materials Needed: 1Oz. of School Glue, 1Tsp. of Borax, 3 Drops of Pink Food Dye, 1 Bowl, 1 Mixing Utensil, 1 1/4 Cup of Water
Safety Hazard: Slime is toxic and should not be consumed. Borax can be harmful if not properly used. Avoid letting the borax-water mixture touch your skin and wash your hands after mixing it into the slime for safety purposes.
Step 2: Add Glue & Water
Add 1 oz. of glue (about 1/4 of a glue bottle) into a bowl with 1/4 cup of water. Do not worry about mixing yet.
Step 3: Make the Slime Pink & Glittery
Add 3 drops of pink food coloring into the mix. Then, add as much glitter as your heart desires. Stir the mixture until both the color and glitter look evenly mixed.
Step 4: Add Borax & Form the Slime
Mix 1 teaspoon of borax with 1 cup of water seperately. Pour the borax-water solution little portions at a time into the slime and stir fast. The slime will begin to form. Pour in more borax until the slime does not stick to the bowl. Once the slime is no longer sticky, it is ready to use! Take it out of your mixing bowl and have fun!
Step 5: How to Store Your Slime
Put you slime into a container that has a lid when your done using it. That’s all! Have fun with your slime and thanks for reading!
