Introduction: How to Play Chinese Speed
Chinese speed is a fun, fast paced, and easy to learn card game.
Number Of Players: 2 to 1
Object Of The Game: To run out of cards as quickly as possible or before the other player
Step 1: How to Start
Start out by passing out the cards till there are none left.Then both players lay the first 4 cards on the top of there deck down on the table.It should look like the picture.
Step 2: How to Play
I will try to explain the best I can but if you still don't understand ask in the comments.Once the cards are laid out count to 3 and say "go".Place random card over any matching numbers(including kings and queens) as quickly as possible.If you get to a point where there are no more matching cards each player picks up his/her side of the cards.Playing by yourself is the same except when there are no more matching cards you pick up your side and discard the other.For example if the cards are like the picture above you would place a random card from your deck over the two 9's and 3's.Then you will continue to cover any matches until you run out of cards or there are no more matches.
