How to Repair Your Renault Scenic Boot Lock Button 1999-2003 Models
72K210
Intro: How to Repair Your Renault Scenic Boot Lock Button 1999-2003 Models
Your boot button has fallen out because the small rubber o ring which holds the button componant in place has worn out and broken causing the button to be ejected.  The picture shows a complete o ring on the left and a perished o ring on the right.  My soloution to this was to produce a cost effective fix fo rthis common problem.  I produced a custom machined metal clip which can be crimped into place and will not wear out.  This can be purchased at my online shop:
http://www.renault-scenic-boot-button.co.uk/
If you have also lost your button these can also be purchased here as well as the spring componant and colour coded button options.  The following tutorial shows how to repair your lock using these componants.  This repair is suitable for Renault Scenic models from 1999-2003 and all Renault Megane models of the same year.
STEP 1: Removing the Interior Tailgate Trim
Open the boot and using the T-20 Torx screwdriver unscrew the four screws, whichhold the interior boot trim in place (some models have an additional two screws near the wiper motor). Unhook the parcel shelf bungees from the trim. To remove the trim, pull firmly all around the edges, you will heara snapping sound, this is just the clips thathold it in place.
STEP 2: Removing the Lock Assembaly
Disconnect the plug from the lock motor and using the 10mm spanner, undo the two fastening nuts which hold the lock assemblyto the tailgate panel.Remove the lock assembly by gently pulling,you will need to release the metal switch lever by sliding it to the bottom of the “L” shaped channel and twisting slightly. Do not force it!
STEP 3: Fitting the Button Into the Lock Assembaly
Line up spring and push the long piece through the hole so it sticks out the back.
As in the second picture, holding back the sprung arm whilst holding the button fully in, place the retaining clip into the recess of the long arm. Using the pliers or mole grips, carefully and firmly crimp the clip onto the arm. When in place, the clip should freely rotate around the arm, but not fall away. IMPORTANT! Ensure the clip is secure!
STEP 4: Re-assembaly
Re attach the metal lever to the sprung arm.  The bent end fits through the bottom of the
“L” shaped slot with the square end.  Bolt the assembly back onto the tailgate panel, remembering to plug the power supply back onto the lock motor. At this stage you can check your installation by closing the tailgate and pressing the button. Also test the remote central locking.
Place the interior trim in place, thump around the edges with a clenched fist to secure, again you will hear a snapping sound of the clips re attaching.
Replace the four screws and reattach the parcel shelf bungees.  All finished, well done!
Again, if you need any componants for this repair, please visit my online shop
10 Comments
I fixed my Renault megane today using these intructions. Thank you very much>
Hi, I recently bought a used 2001 Renautt I Scenic 1.4i. The car is fine, apart from the fact that the boot does not lock. It goes rrrrrrrrrrrrrrrrrrr, but stays open. I live in Durban, South Africa. Any suggestions from anybody?
Remove the interior tailgate trim and check the linkage arm between the solenoid and latch, something could be loose or broken.
I've got exactly the opposite problem. I went to open my Scenic boot and the button remained jammed in (and the boot didn't open either).
I suspect somethings' broken inside the lock mechanism. Is there any way to release the boot from the inside?
I've come across this a couple of times. There is no internal release for the Scenic. The solution I came up with is to let the back seats down and crawl into the boot space. Using a drill with tank cutter (about 70mm is big enough), carefully cut a hole in the interior trim, in the centre, behind the lock assembaly. Now you can access the workings of the lock and un-jam, get the boot open and and fix the fault. Now you just need to fix the hole. I used another flat piece of interior trim which I had lying around and cut a neat square panel to bolt over the hole, if done neatlly it doesn't look odd. Sounds brutal, but I've seen people who have tried kicking it from the inside out and done a lot of damage to the mechanism and body work. Good luck.
Thanks for the quick response.
After a lot of jiggling the button, spraying it with WD40 etc. the button suddenly popped back out and thankfully it is working again and the boot opens. However, the "click" the button makes when I press it sounds odd so I suspect something is damaged inside.
I'll investigate replacing the mechanism a.s.a.p. before it really does break permanently!
Thank you for taking a look at this tutorial.  Our aim is to supply a cost effective repair to this common fault and help you get you boot lock back in working order as quickley and cheaply as possible.  Please visit our ebay shop http://stores.ebay.co.uk/renaultscenicbootbuttons-2008?_rdc=1
repaired mine today, works well, good repair, and only £3.50 a lot cheaper than buying a new colour coded handle. well happy.
