Introduction: How to Replace the Blade on a 9 Inch Bandsaw
Step 1:
First you need to unplug the saw. Then you need to buy a blade to fit on the bandsaw, mines a 59.5 inch blade, you then neet to open the saw
Step 2:
You then need to loosen the top pully using the lever on the back then put then blade on the pulley
Step 3:
You need to fit the blade on the pullies, this may be tough. You need to then pull the lever on the back to tension the blade
Step 4:
You now need to make the blade track straight using the knob on top. You should use your hand to turn the pully
Step 5:
Once you have the blade tracking well, you should plug it in. Then you should close the cover. Then turn on the saw , but be ready to either turn off or adjust the saw in case something goes wrong. As its going adjust the blade, the saw should have a small "window" to view the blade.
Step 6:
And your new blade is on! Fell free to follow and or comment
