Introduction: How to Tie a Tie
This is a detailed explanation about how to tie a tie. This how to covers the most common knot known as the Windsor Knot. After seeing many of the other tie e-hows, I decided to make a how to myself. I am the owner of a website that shows its viewers how to tie 15 different knots. I made these diagrams to help guide you through. There are also 15 different Youtube videos published on how to tie a tie.
How To Tie a Windsor Tie Video
To learn the Half -Windor Knot Instead..
How To Tie a Half Windsor Tie
Step 1: How to Tie a Tie Step 1
http://www.2tieatie.com/images/windsor-knot-step-1.jpg
Drape the tie over your neck, with the wide end of the tie on your right. The wide end should hang about a foot or so lower than the narrow end.
Step 2: How to Tie a Tie Step 2
http://www.2tieatie.com/images/windsor-knot-step-2.jpg
Cross the wide end over the narrow end and bring the wide end up and through the inside of the loop around your neck
Step 3: How to Tie a Tie Step 3
http://www.2tieatie.com/images/windsor-knot-step-3.jpg
Bring the wide end back down, around and behind the narrow end.
Step 4: How to Tie a Tie Step 4
http://www.2tieatie.com/images/windsor-knot-step-4.jpg
Pull the wide end up on your right, then put down through loop and across the narrow end. (Refer Step 4 and 5)
Step 5: How to Tie a Tie Step 5
Step 6: How to Tie a Tie Step 6
http://www.2tieatie.com/images/windsor-knot-step-6.jpg
Turn and pass up through the loop around your neck. (Refer Step 6 and 7)
Step 7: How to Tie a Tie Step 7
Step 8: How to Tie a Tie Step 8
http://www.2tieatie.com/images/windsor-knot-step-8.jpg
Complete the knot by pushing the wide end down through the front of the knot.
Step 9: How to Tie a Tie Step 9
http://www.2tieatie.com/images/windsor-knot-step-9.jpg
Tighten the knot carefully as you flatten out any wrinkles.
