Introduction: How to Crochet Snoopy
For this cute Snoopy you just need 2 colors (White and Black), you need crochet hooks (depending on the size of your yarn and which crochet hooks you personally prefer), and to finish off the strings and embroider details your going to need a crochet needle. And you will need stuffing.
What everything means...
sl st - slip stitch
sc - single crochet
dc - double crochet
hdc - half double crochet
dec - decrease
mr - magic ring
inc- increase
hdc dec - half double crochet decrease
sc dec - single crochet decrease
The perenthisis () with a number it it at the end of the row is how many stitches you should have after that step
Step 1: Head
In white...
1. Magic ring (8)
2. Inc each (16)
3. (sc, inc) until you reach (24)
4-5. sc (24)
6. (2sc, inc) until you reach (32)
7-11. sc (32)
12. (3sc, inc) until you reach (40)
13. sc (40)
14. (5sc, inc, sc) do this 5 times, then 25sc (45)
15. 3sc, inc, 3sc, inc, 8sc, 3sc, inc, 24sc (49)
16. 5sc, 17 dc, 27sc (49)
17. 5sc, 17dc, 27sc (49)
18-20. sc (49)
21. dec, 2sc, dec, 14sc, dec, 2sc, dec, 23sc, (45)
22. (3sc , dec) until you reach (36)
23. sc (36)
You should now start stuffing the head and keep stuffing it as you crochet
24. (4sc , dec) until you reach (30)
26. (2sc , dec) until you reach (18)
27. ( sc , dec) until you reach (12)
28. dec each st until you reach (6)
Now take your crochet needle to finish it off by hiding the unwanted string
Step 2: Finishing the Face
In black yarn...
Start adding the facial features I added the eyes about 8 st from where you can see the dc started in the head and I made the eyebrows about 3 or 4 st above the eye. Then I added the mouth, when you add the mouth just make sure that each side is even . And then you can crochet the nose to the very end of it. And here is the pattern for the nose...
1. Mr (5)
2. inc each (10)
3-4 . sc (10)
Then stuff it just barely and finish it off and leave a tail of yarn to connect it to the head
Step 3: Ears
Make 2 from black yarn
1. mr (8)
2. inc each st (16)
3- 12. sc (16)
now fold the ear in half and crochet it together, fasten off (leave yarn tail to sew on the head)
Step 4: Body
In white...
1. mr (8)
2. inc each st (16)
3. (sc , inc) until you reach (24)
4. (2sc , inc) until you reach (32)
5. (3sc, inc) until you reach (40)
6. (4sc, inc) until you reach (45)
7-10 sc (45)
11. (4sc , dec) until you reach (40)
12-14. sc (40)
15. (3sc, dec) till (32)
start to stuff the body to give it shape
16.-17. sc (32)
18. (2sc, dec) till (24)
19-20. sc (24)
21. (2sc, dec) till (18)
22. (sc, dec) till (12)
23. sc (12)
24. (sc, inc) till (18)
Fasten it off and leave a tail
Step 5: Arms
In white make 2...
1. mr (6)
2. inc each st (12)
3. (sc, inc) till (18)
4. sc (18)
5. (sc, dec) till (12)
now start to stuff the arms
6. (sc, dec) till (8)
7. 4hdc, 4sl st (8)
8. 4hdc, 4 sc (8)
fasten off, leave tail for attaching it, and embroider black for the fingers for the arms
Step 6: Legs
Make 2 from white yarn...
1. ch 9, do 2sc in the 2nd ch from your hook, then 6sc, 5sc in the next chain, now you are going to want to want to go to the other side of the eg and 6sc, and 2sc in the last stitch and you should now be at (21) if you did it correctly
2. 2 inc , 7sc, 3inc, 7sc, 2inc (28)
3. inc, sc, inc, 10sc, 2inc, 10sc, inc, sc, inc (34)
4. sl in each st (34)
5. sc in each stitch and turn
6. 2sc dec, 8sc, 5hdc dec, 8 sc, 2sc dec (25)
Now I like to start stuffing it
7. 2hdc dec, 4sc, 2hdc dec, hdc dec, 4sc, 2hdc dec (17)
8. dec each st then do one sc (9)
9.-12 sc (9)
Fasten off, leave yarn tail, use black yard to put toe lines on the foot
Step 7: Tail
With white...
1. mr (4)
2. (sc, inc) do this 2 times (6)
3. (2sc, inc) do this 2 times (8)
4. (2sc, dec) do this 2 times (6)
5. (sc, dec) 2 times (4)
6. optional - if you want to have your tail a little bit longer you can do an extra row of just sc
fasten off, leave yarn tail
Step 8: Attaching the Pieces Together
Now you need to connect all the pieces together using your crochet needle. First start by attaching the ears to the face making sure they are both evenly placed where you want them. I put mine about 3 stitches down from where the eyes ended. then attach the body to the face and after that add the collar to the neck.
Collar in black...
ch 17
turn over ( skip first st) sc 16
Once done with that place the arms on the side of the body making sure that the black embroider is facing forward. Place the arms a little less than half way down the body. Next add the feet at the bottom of the body only a few stitches away from each other and again make sure the black embroidered part is facing forward.
Step 9: Your Snoopy Is Completed!
Now your snoopy is done and if you would like put in the comments what you think would improve it, or how your snoopy turned out!
