Introduction: How to Dance in LED Glow Wings
Here are some moves you can use to dance in your LED glow wings for a performance of just for fun!
- LED glow wings & rods
- Large open dark space
Step 1: Starfish
Hold the wings at your sides. Quickly bring the wings up above your head then bring then back to the starting position. Do this repeatedly as if you are making a snow angel in snow.
Step 2: Backward Wing Throw
Hold the wings by the rods in front of you. Quickly throw the wings backwards and then return tho the starting position. Do this repeatedly for a flying effect.
Step 3: Forward Wing Throw
Hold the wings by the rods over your shoulders. Quickly bring then in front of you and return to the starting position. Do this repeatedly for a flying effect.
Step 4: Figure of Eights
Hold the wings directly in front of you, parallel to the ground. Move the rods as if they are drawing a figure of eight in the air. To practice you can do one arm at a time. You can try moving the wings fast and slow for different effects.
Step 5: Move With the Wings
Hold the wings out to the sides and run or walk in a circle. The faster you go the more the wings move with you.
Step 6: Swirl
Hold the wings high and spin around in place.
Step 7: Arm Circles
Move the wings in circles by holding the rods and circling them around. You can do the circles forward or backward.
Step 8: Clap With the Wings
Remove the rods. Put your arms under the wings and hold you arms out to the side. Clap your arms in front of you then return them to the starting position.
