Introduction: How to Draw: Anime-like Face
You will be learning how to draw this long-haired male with a blue streak
Step 1: Materials
Here's a list of materials that you need for this drawing:
Paper or Sketchbook
Pencil
Eraser
Inking pen (I used Micron 03)
Markers (I used Blick Studio Brush Markers)
Step 2: Step 1
First, you sketch out a circle. Then you draw a line with a wide V shape at the end.
Step 3: Step 2
After that, you start sketching out the chin and cheek part of the face. Be sure to try and make it symmetrical.
Step 4: Step 3
Then, draw 3 horizontal lines marking where the eyes and mouth go. Try to make them parallel to each other.
Step 5: Step 4
Sketch out vertical lines marking where the eye starts.
Step 6: Step 5
Start to sketch out an egg shape to make up the eye. Widen the bottom part so it doesn't look so much like an actual egg, though.
Step 7: Step 6
Make the pupils of the eyes and the shimmer in the eye. (I messed up on them in further steps)
Step 8: Step 7
Sketch out the nose and the mouth. Make the nose a right triangular shape that is shaded black. Then I draw the mouth like 2 dashes. ( _ _ )
Step 9: Step 8
Start drawing the hair to make up a frizzy-type long hair so that it makes up of a male-type long hair.
Step 10: Step 9
sketch out 2 horizontal lines to make up the base of the neck. (usually, males have bigger necks than females in drawing the anime-type face. This is a male, so have a bigger neck like in this image)
Step 11: Step 10
Draw the neck out.
Step 12: Step 11
Outline the drawing with your inking pen.
Step 13: Step 12
Add any additional details with the inking pen. (ie shading, filling in small gaps, etc.)
Step 14: Step 13
Lastly, Color in with markers. Make sure to add the streak in his hair.
Step 15: Done!
You are finally finished! You can do this whichever way you want! Remix it! Change it up a bit! It's all yours to do! Thanks for doing this tutorial if you did, and don't forget to keep drawing!
