Introduction: How to Fix a Broken Bag Buckle
Sometimes that plastic buckle that holds your bag straps snaps and you're left with no easy way to join them back together. Luckily FixIts is strong enough to hold them together and can fix it back to new in less than 10 minutes.
Ways to boil water :
- Kettle
- On a hob in a pan
- Heat cup of water in Microwave (without the FixIts stick)
Vessel (avoid plastic as FixIts can stick to it)
- Glass cup or
- Ceramic cup (preferred as it retains heat)
Step 1: Soften FixIts Stick
Four easy steps, Heat water, Dunk you FixIts for at least one minute in the hot water, remove your FixIts, Pinch off what you need.
Step 2: Mould a Small Cylinder From FixIts
Start by rolling a small blob of FixIts between your fingers into a cylindrical shape. Make it a little bit larger than the length of the bag loop, so that the other bits of moulded FixIts can attach to it. Wait until the FixIts cylinder has cooled and hardened and slide it into the bag loop to check whether it fits in it properly.
Using the FixIts cylinder you made as a guide, mould the other two arms of the buckle.
Top tip: cool your shaped FixIts quickly in cold water.
Step 3: Dip Ends Into Hot Water and Attach Them Together
Dip the ends of the moulded FixIts into hot water (or use a hairdryer on hot), when they have softened, attach the arms together - as shown above. Smooth out the edgeswith your finger.
Step 4: Slide the Half - Made Buckle Into the Loop
Slide the partially completed buckle into both the loops of your bag, and use this as a guide (length and thickness) to mould the final arm of the buckle.
Step 5: Attach the Fourth Arm of the Buckle
Dip the ends of the FixIts buckle into hot water or use a hairdryer on hot to soften them and finally mould them together.
Top tip: Use a hairdryerto add some finishing touches (smoothening out the edges, shaping the arms of the buckle, etc..)
Step 6: Back to New!
Back to working and good as new!
