Introduction: How to Install a Screen Door
Today i am going to walk you through how to install a screen door! the materials you will need is a saw, screwdriver, drill, and a tape measure. then unpack all the contents of the box.
Step 1: Step 1:
slide on plastic pieces and tighten them into place so the door doesnt rattle around.
Step 2: Step 2:
slide metal top onto both screen doors, then screw on a plastic cap so it doesn't slide down.
Step 3: Step 3:
drill metal holder onto door frame to hold in the screen door.
Step 4: Step 4:
clamp doors onto metal holders.
Step 5: Step 5:
Cut down the track with the saw so it fits in your door frame, then slide the track into the bottom of the door
Step 6: Step 6:
Cut the larger track down to the size of the door as well, then slide it into the top of the door and drill it into the top of the door frame so it doesn't fall out.
Step 7: Step 7:
Now your done! hopefully this helped you install your own screen door!
