Introduction: How to Interface a 4x3” TFT Display With an Arduino
FocusLCDs.com sent me a free sample of a 4x3” TFT LCD (P/N: E43RG34827LW2M300-R) to try out. This is a color active matrix TFT (Thin Film Transistor) LCD (liquid crystal display) that uses amorphous silicon TFT as a switching device. This model is composed of a Transmissive type TFT-LCD Panel, driver circuit, backlight unit. The resolution of a 4.3” TFT-LCD contains 480x272 pixels, and can display up to 16.7M colors.
For this project, you would need the RA8875 driver board (available at AdaFruit for US$35) to interface the TFT display to the Arduino. It comes with a header which you can solder on as needed.
Summary of Features
- 480x272(105.4x67.15), 8/16/18/24-bit RGB interface
- WHITE LED backlight, Top view
- Wide temperature
- Transmissive, 4-wire Resistive Touch Screen
- 300 NITS
- Controller: ILI6408B
- RoHS Compliant
Step 1: Materials Needed
Materials
- Arduino UNO
- 4x3” TFT LCD; E43RG34827LW2M300-R
- RA8875 40-Pin Driver Board
- Solderless Breadboard
- Dupont Jumper Wires
- 2.54mm-Pitch Headers
- Arduino IDE
- USB Cable
- Soldering Iron
- Soldering Lead or Tin
Step 2: Step 1: Connect RA8875 Board and Install Libraries.
- Solder the accompanying header to the RA8875 board.
- Download and install these Adafruit libraries. Just copy and paste the unzipped folder to Documents/Arduino/libraries (in Windows 10). Note that the Arduino IDE doesn’t like dashes “-“ in the filenames; just replace it with an underscore “_”.
- Adafruit_RA8875_Master (https://github.com/adafruit/Adafruit_RA8875)
- Adafruit_GFX_Library_Master (https://github.com/adafruit/Adafruit-GFX-Library)
- Adafruit_STMPE610_Master (https://github.com/adafruit/Adafruit_STMPE610)
- Connect the TFT display to the RA8875 board. Take note that the display should be facing up.
- Connect the Arduino to the RA8875 board like so in the image:
- RA8875 VIN to Arduino UNO 5V.
- RA8875 GND to Arduino UNO GND.
- RA8875 SCLK to Arduino UNO Digital #13.
- RA8875 MISO to Arduino UNO Digital #12.
- RA8875 MOSI to Arduino UNO Digital #11.
- RA8875 INT to Arduino UNO #3.
- RA8875 CS to Arduino UNO #10.
- RA8875 RESET to Arduino UNO #9.
Step 3: Step 2: Open an Example Sketch and Customize.
- Fire up you’re the Arduino IDE. Take care to select the correct board i.e. Arduino UNO or MEGA, etc. and select the correct COM port.
- In the Arduino IDE, select File>Examples>Adafruit RA8875>buildtest
- In the sketch, look for line 39: “if (!tft.begin(RA8875_480x272)) {“… Make sure “RA8875_480x272” is indicated.
Step 4: Step 3: Upload the Sketch and View the Result.
- Upload that sketch to the Arduino UNO by pressing CTRL-U.
- And voila! Your screen should show something like this.
