Introduction: How to Make 18650 Li-ion Charger Station for a Budget
A lithium-ion battery or Li-ion battery (abbreviated as LIB) is a type of rechargeable battery in which lithium ions move from the negative electrode to the positive electrode during discharge and back when charging. Li-ion batteries use an intercalated lithium compound as one electrode material, compared to the metallic lithium used in a non-rechargeable lithium battery. The electrolyte, which allows for ionic movement, and the two electrodes are the constituent components of a lithium-ion battery cell.
Lithium-ion batteries are common in home electronics. They are one of the most popular types of rechargeable batteries for portable electronics. Because there are so popular i decided to make a cheap charger that everybody
can replicate at home.For this project we going to need the following stuff:
Some charge board module for charge control the battery 4.2v fully charged 3.7v nominal and 3.0v empty
18650 Battery holders
Case or cardboard
wires
So let's get started
Step 1: My Source for 18650 Li-ion Battery
I take the battery from Poundshop power banks and inside these 1£ power bank there is the small module,
the battery, plastic casing, some rope wire thing and for a small application these batteries are more then ok
this is written on them 18650 1200Mah but i don't think for that price is the actual power but 900Mah is good enough
for lights, small motors like pc fan, relay, radio, charge the smartphone with 4xbattery 2 times fully charged
and manage to power multiple USB devices for a couple of hours.This charger that we will make charge the batteries 4 of them separately with 4 individual controllers
Step 2: Charge Modules Tp4056
This is the module in charge of charging the 18650 to 4.2v and the stop the charging process
and they have an over protection of low voltage for 3.2v they flash a blue led and disconnect the power
they required a 5v power supply of approx 1A they are not polarity protected so if you connect the battery to wrong position boom the small charger is burned
Step 3: Power Bank Poundland
All the stuff that you end up when you buy this power bank
First thing you have to solder wires like in the picture and just connect the charge module
according to the battery holder and remember do not reverse the battery
additional you can add some switches on all the modules
put the parallel connections and connect to the power supply
it has to be at least 5v 1.5A
Step 4: Cheap I Max Charger
As improvement, we can add a constant current tester
can be made by another power bank in between battery and controller connect the multimeter
as a load, we going to connect a USB lamp because in the discharging process is no need to lose the energy
we gonna power this USB light and a start-stop clock to record the time
At the end of the discharging process, we will find the capacity of battery by multiplying the time with the power consumption /60
Thanks for watching and please visit the channel on youtube.
