Introduction: How to Make
I chose to make "la mitad del mundo" because it is an important part of ecuador and is one of, if not the most famous monuments of Ecuador. Its a very visited place, where tourist and locals alike go to learn more about Ecuador. It was an interesting project and one that I believe helped me better my skills.
Step 1: Step 1: the Base
I made the base by using the box tool and making it as big as it needed to be i then started to use the same tool to make the base more detailed, as well as making four columns .
Step 2: Step 2: the Main Column
The main column is the most important part of he project, so what i did was using the box tool again I made a rectangle and in front of that another rectangle, less wide as i wanted it to look like a name plate. Then finally a put a square base on top, as a base for the sphere (using the sphere tool to make it)
Step 3: Step 3: the Ground
The ground is easy to make using the box tool and making a wide enough square but making so it is has no height, the using the tube and making just a bit taller the the square, then changing the radius and the wall thickness until it looks as similar to the original.
