Introduction: How to Make Abstract Art With Rose
Hello! Today we are going to make a semi-easy Abstract Rose with coloring!
Step 1: What You Need:
• 1 Piece of Paper
• Pencil (Not mechanical)
• Flat Surface
• Coloring Materials (Colored Pencils, Markers, Ect.)
• Optional: Sharpie & Eraser
You will need 1 piece of paper either in a notebook or just singular. Next you will need any pencil. I would recommend not using mechanical because it is super light.
• Flat Surface
Step 2: Draw a Rose: Pt:1
Start by drawing a stem. Draw a singular line. MAKE SURE THIS ROSE IS NOT IN THE MIDDLE, HAS SPACE FOR THE ENTIRE ROSE, AND NOT TO BIG.
Step 3: Draw a Rose: Pt2
Here we are going to add some leaves onto the stem. Doesn't have to be perfect, we will go over later.
Step 4: Draw a Rose: Pt3 Making the Petals
Making the petals. Since we are doing an abstract drawing, make a swirl from big to small. The small will be the inside.
Step 5: Adding Detail to the Rose
Here we are just going to add detail by making leaves on the rose.
Step 6: Making Abstract Lines
Here we are going to scribble. Pretended there is a way to scribble in cursive. What ever shape you like. MAKE SURE TO CONNECT BACK TO THE ROSE.
Step 7: Optional Step: Trace & Erase
Trace with sharpie and then erase the pencil lines.
Step 8: Coloring!
Color in between lines. If a line crosses another line and creates a closed room/space, color that. Choose any color besides the color you used with the sharpie. Color the rose!
