Introduction: How to Make a Homemade Mini Air Cooler
About: I enjoy making new Instructable
Making make air cooler with cpu fan is simple and easy project using only basic parts of air cooler
if you don't understand something please watch the video and vote :)
Step 1: Things We Need
10 lite bottle
Water pump with pipe
Pointer pen
Thin net
Beso
2x cpu fan
zipties
Step 2: Making Exhaust and Inlet
Cut a piece of 6 by 6 inches from backside and then cut two holes from the front by 3.5'' cutter
place fan over the hole and drill out the screw positions of the fan and another hole next to those holes as well
put the fan from inside the bottle and tighten both the fans with zipties
Step 3: Making Evaporative Window
Cut out benso pieces around 8 inches
Place them over the thin net and secure it from all over the edges by stapler
Step 4: Setting Up the Water Pump
Place pipe from to the exit part of the motor and then pointer on the exit of pipe make holes on the pointer body and attach it to the top of the evaporative net with zipties
Step 5: Placing the Things
make a hole from the side of bottle and take out both the fan and motor wire outside wire them up with bigger wire
place the motor inside and the evaporative window as well
Step 6: Final Steps
cut out the top part of the bottle , make hole where the evaporative window will be hang by zipties
place the water from the inlet window and place the top part of the bottle upside down over the cooler .
Place the wires into the 12v supple and it will start working turning hot air into cool air
It works great if you don't understand something please watch the video and vote for this instructable :)
