Introduction: How to Make Brass Wax Seals
Let’s make your brass into wonderful wax seals! Laser etching can creates deep custom designs on brass easily.
Ready to give your laser etching brass wax seals the attention they deserve? Check out the steps below and etch your way to success!
Machine Used
Aurora Lite 50W
Material Needed
Brass
- Laser Etching
- Speed: 1000mm/s
- Marking Power: 90%
- Frequency: 50kHz
- Line interval: 0.02
- Laser Cleaning
- Speed: 1000mm/s
- Marking Power: 20%
- Frequency: 70kHz
Step 1: Place the Brass Wax Seals for Laser Etching
Put down the brass wax seals.
Step 2:
Load your design into LightBurn software, adjusting its size and position to fit you brass wax seals. Then make sure the laser etching parameters are set correctly.
We prepared two layers. The black one is responsible for leaving a deep etching on the brass, while the red layer cleans the brass surface after the laser etching.
Step 3: Don't Miss the Focus
Missing the focus is one of the biggest reasons for laser etching failure. So don’t forget to click the AF button for auto focus. Of course, manual focus is also effective.
When two red dots are displayed on the brass, it is out of focus. When the two light dots overlap each other, it means in focus.
Step 4: Ready to Start Laser Etching
Press the frame button and check if the visual red light indicate the right area to be etched. The frame should fit the brass seals. If not, move the pattern positions until they align.
After checking, close the laser door and begin Aurora Lite’s operation.
Step 5: Monitor the Brass Wax Seals Laser Etching
Stay near the machine throughout operation to monitor for any unusual sounds or alarms. This vigilance ensures safety during etching, as laser energy is potent. Avoid looking directly at the laser beam, even with protective measures in place.
Step 6: Complete the Laser Etching
Once laser etching is complete, carefully open the door and get your newly personalized brass wax seals. Laser etching does not produce toxic substances, and you can use the laser etching brass wax seals after a simple cleaning!
Brass wax seals add a touch of elegance and tradition to your letters, invitations, and packaging. Crafted for durability and precision, these laser etching seals create crisp, detailed impressions in wax, making every correspondence feel personal and distinguished. Whether you’re sealing wedding invitations, business documents, or handmade gifts, laser etching brass wax seals offer a timeless and stylish way to leave a lasting impression.
#Laseretching #FreeLaserFiles #LaserCrafting #DIYProjects #CraftTips #UniqueGifts #PersonalizedGifts #GiftIdeas #BrassWaxSeals #PersonalizedSeals #CreativeCrafting #SealsYourStyle #DIYSeals #LaserCraftWaxSeals #LaserEtchDesign #SealsDesigns
