Introduction: How to Make Coconut Oil
About: I love cats that hate me, gin and dressing up. Writing is my passion and I hope to be able to cosplay more frequently in the future
What you need
Coconut
Drill or some way to tap into it
Vise or some way to open it
Knife
Bowl
Jar
Pan
Blender
Step 1: Buy a Coconut
I just got mine from the Greengrocer
Before you start this project do be warned that it is a lot of effort for very small yield, so you may want to use more than one
Step 2: Get the Water
A coconut husk is freaking hard so this does require some elbow grease
Alternatively just use a drill like I did to tap into the coconut and decant the water into a bowl
Step 3: Crack It Open
Initially I tried this with a hammer but it was so hard it made no difference (or maybe I am just really weak)
Instead I put it in a vise and slowly wound it up until it cracked the coconut open
Step 4: Get the Meat
Now you can move from the workshop to the kitchen.
Using a knife, carefully cut out the flesh.
It's ok if you get the brown bits in there, they are still edible
Make sure to cut them into small enough pieces that your blender can handle
Step 5: Blend It
Add the pieces to your blender.
Mine is pretty small so I to do it in batches.
But before you start blending, boil up some water (hot water helps extract more coconut oil)
Once boiled, add some hot water (enough to cover the pieces) and if you need add a little cool water so that it is not scalding hot.
WARNING - ensure the lid is on properly, being splashed with hot coconut water burns. A lot.
Blend everything together until the coconut pieces resemble desiccated coconut bits
Step 6: Strain the Water
Strain the now blended mixture into a bowl
You can also add the coconut water that you extracted initially if you wish
Step 7: Put It in the Fridge
Once you've strained everything, you can put the bowl in the fridge overnight.
You will clearly begin to see a separation in the liquids.
The top can form a hard layer which is your coconut oil.
The desiccated coconut, you can spread out and dry and use as you wish
Step 8: Boil and Decant the Oil
For the final step, once you have left the milk overnight, you can take it out and bring it to the stove
Add everything into a pan
Over a medium heat, bring the liquid to a boil
You will begin to see the water boil off and the thicker oil remain behind.
Boil it until it becomes clear and immediately decant into a jar or container
And there you have it - coconut oil!
